Coolant Type And Changw
Posted 10 June 2019 - 12:10 pm
Right, so I'm touring in the Alps in 3 weeks time. I've changed oil and filter (just as well as the whoever did the last change put the filter in upside down....)
Bled brakes but still not the "feel" I'd like and one bleed nipple is blocked so I've got braided hoses new bleed nipples and fresh fluid lined up.
I thought the coolant tank was a little low so I topped it up with what I thought was Prestone "goes with anything" stuff... But it wasn't D'oh! I've missed the old green stuff in there with pink OAT stuff for the missus old Celica so the old girls going to get a coolant change as well.
The manual says "use a quality ethylene glycol" so that's what I've bought. Saw the front of the bottle in the auto store and it said ethylene glycol. When I got it home I noticed on the back it is, in fact, an OAT version. Bearing the systems going to get a full drain will the new OAT ethylene glycol stuff be ok? Also am I right in saying I need to drain the system from the water pump, cylinder block face and the expansion down pipe?
Bike is an 04 with 57k.
Posted 10 June 2019 - 12:58 pm
Enjoy yer trip.
Posted 10 June 2019 - 01:14 pm
I normally empty from the water pump and cylinder block face but you'll only get a dribble from that location, usually stick the hose pipe furra quick flush then fill up straight away, leave on side stand, cap off while idling to remove any air.
Off to the Alps, lubberly been awhile since last out that way..
Posted 10 June 2019 - 02:25 pm
You'll also have to empty the reservoir bottle behind the RHS cover. I used a medical syringe and a piece of hose.
Riggers.
Posted 10 June 2019 - 07:24 pm
Posted 10 June 2019 - 10:51 pm
oil filter upside down, i didn't think that was possible and i'm surprised the enjun hasn't seized?
Posted 11 June 2019 - 02:44 pm
always a good idea to cable tie the front brake lever to the bar overnight after a fluid change
