i need to do a deep clean on my chain can i use a ethanol based degreaser on a o-ring chain
Chain Cleaning
Posted 22 June 2018 - 08:08 pm
Posted 22 June 2018 - 08:13 pm
Ya mean petrol i use wd40 wipe off then oil it, someone will come along and tell you wd40 will knacker ya chain i guess, not had a problem in 40,000 miles doing it though..
Posted 22 June 2018 - 08:17 pm
no its not petrol but an actual degreaser
Posted 23 June 2018 - 11:41 am
Dunno but I use engine oil. Used to use diesel.
Posted 23 June 2018 - 04:17 pm
I've always used paraffin to clean the chain and then gearbox or engine oil to lube it using a paint brush. Never had a problem.
Riggers.
Posted 23 June 2018 - 05:36 pm
Posted 23 June 2018 - 08:25 pm
I would be wary of a dedicated degreaser. If it gets into the o-rings it may dissolve the grease in the rollers shortening the life of the chain.
I've always used something which evaporates quite quickly, like kero, petrol, and on occasion wd40, which is mainly kero anyway.
You only need to clean the links, not the pins in the rollers. I use an old margarine tub under the lower run of the chain with kero in it and give the chain a good scrub then wipe it dry and re-lube.
Chains last me forever and only get adjusted when I change tyres despite a lot of dusty gravel riding and occasionally riding through water.
Ethanol can affect seals in some engines, it may affect rubber o rings.
Posted 23 June 2018 - 11:00 pm
