Crappy Freelander 2 Warning Light
19 replies to this topic
#1 dapleb
  • 18,117 posts
Posted 18 October 2018 - 05:24 pm
Tishabelles shart truck... I'm on the IOW so don't have any books. Does anyone know what item 28 in this ear linky dink could be?
https://www.landyzon...-46-png.104840/
If ever I need a reminder of how ridiculous electrickery driven junk can be this ve-hickle manages to do it.
Hopefully soon to be upgraded to a 10 year older green slug.
#2 PICARD
  • 1,744 posts
Posted 18 October 2018 - 06:00 pm
Just had a little doogle and the nearest I could find (but red) is ESP traction control fault. The fact that it's amber suggests not urgent / dangerous. Good luck no doubt a proper expert will be along shortly.
#3 dapleb
  • 18,117 posts
Posted 18 October 2018 - 06:17 pm
Ta capn.
#4 Apache
Apache
  • 553 posts
Posted 18 October 2018 - 06:23 pm
Usually on when TC has been switched off Dap. Check switched on..
Edit....default is on, check not switched off..
Edited by Apache, 18 October 2018 - 06:25 pm.
#5 Studley Ramrod
  • 19,214 posts
Posted 18 October 2018 - 06:44 pm
Blimey, how many lights do ya need ! :huh:
#6 dapleb
  • 18,117 posts
Posted 18 October 2018 - 07:02 pm
Thanks chaps.
It apparently came on without any buttons being pressed when enjun started. Stayed on. When key removed and put back in it stopped.
#7 trevini
trevini
  • 1,777 posts
Posted 18 October 2018 - 07:27 pm
Get the battery checked Dappers. If the crankIng voltage is too low, you may get random warning lamps appear. Chances are, it’ll be fine, but worth a look.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy,  Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators   Currently not fitted - PC3, Remus Revolutions.
#8 dapleb
  • 18,117 posts
Posted 18 October 2018 - 08:28 pm
Thanks twev, battery new ish after the common HDC fault which the battery didn't fix and was related to the common starter motor fault and the common software update fault.
It also has the common and ridiculous electronic steering lock fault.
The underneath has the common made of very cheap steel fault as do the calipers, discs and suspension components.
I don't know if the key randomly locking (or not) various door combinations on any given occasion is common but it is ridiculous.
I will spend the weekend waxoiling an 8 year old ve-hickle as otherwise in a year or so the various cheap crap components/chassis will be MOT test failures!
Thanks for the help chaps, good to know that its not an urgent illumination.
#9 trevini
trevini
  • 1,777 posts
Posted 18 October 2018 - 09:05 pm
I'm a Land Rover man at heart, having had loads over the years as green lane/trials vehicles, but there's no way I'd have any land Rover model newer than about mid 90's. The last one I had was a P38 Rangie, which was alright for the time I had it, though I did spend a fair bit on uprated air springs (Arnott longer travel hobbies from USA) and preventative maintenance. I might consider going back to a Defender, but having had Jap 4x4s for the last two, LR products now seem overpriced and poor value.
Hope you get it sorted Dappers. What are you looking to replace it with?
#10 dapleb
  • 18,117 posts
Posted 18 October 2018 - 09:17 pm
Me too love em. My series tree had 1 wire, no steering lock and it worked fine. 😀
#11 dapleb
  • 18,117 posts
Posted 18 October 2018 - 09:26 pm
I plan on replacing it with an udder diesel 306..... it's Tishabelles ve-hickle but she has about had enough of it and the 306 is free!!
#12 trevini
trevini
  • 1,777 posts
Posted 18 October 2018 - 10:02 pm
The last trialler I had started off as a One owner, full history Vogue Se Rangie. Ended up bobtailed, lifted body, 4.1 ratio Detroit lockers at both ends running on 35 boots. It was virtually unstoppable.Attached File  F3B68D06-6123-4627-A49B-34F5540FBD41.jpeg   152.36KB   0 downloads
#13 dapleb
  • 18,117 posts
Posted 19 October 2018 - 03:17 am
Haa very neat especially the name. :Lolzio:
#14 trevini
trevini
  • 1,777 posts
Posted 19 October 2018 - 06:06 am
The name came from a met of mine (who passed away a couple of weeks ago RIP Ade) It came from the act that if you block a Badgers path, itll just stand there and shake angrily. Summed the motor up to a tee.
#15 Studley Ramrod
  • 19,214 posts
Posted 19 October 2018 - 01:33 pm
:lol:
#16 PICARD
  • 1,744 posts
Posted 19 October 2018 - 02:50 pm
Don't wish to be a party pooper, but I think the wheel alignment may be a tad out. Could be wrong!
#17 dapleb
  • 18,117 posts
Posted 19 October 2018 - 03:00 pm
Great. Never have blocked a badger but but curiosity means oil have to give it a whirl!!
#18 ChrisG
  • 8,276 posts
Posted 19 October 2018 - 03:17 pm
If it's the 1.9 TD rather than the 2.0 HDI check which fuel pump it's got. The Bosch pumped ones run fine on veg oil instead of diesel
#19 dapleb
  • 18,117 posts
Posted 19 October 2018 - 03:35 pm
Mine is the none any turbo one....69hp of fury! Has the Lucas pump. Despite what I have read, one of my pug amigos runs his on neat veg oil in summer with Lucas pump... Though I ain't about to try it. Smells loike a BBQ following him.
The one Tishabelle might have is a HDI.
#20 ChrisG
  • 8,276 posts
Posted 21 October 2018 - 07:27 pm
I always found I fancied chips when I was running my ZX on veg oil :D  Presumably with the Lucas pump he's preheating it and running a separate tank rather than just chucking it in the diesel tank.
