Custom Made Exhaust Link Pipes - Help Wanted
Posted 08 November 2015 - 08:54 pm
The exhaust on my old Divvy which I am putting back on the road is blowing quite badly so I took off the end can today. To cut a long story short, the 4 into 2 down pipes are fine but the box is knackered. It goes from 2 into 1 and the pipes are rotten. The box itself is pretty tatty too and holes are starting to appear. It is a Motad Nexxus and it doesn't look like I can get a new one. It would be simple enough to fit an aftermarket end can, which I can get for little money, but I will need a custom made link pipe.
Can anbody point me to someone able to make me up the required link pipe?
Ali
Posted 09 November 2015 - 09:22 am
......try Roy Osborn at OSPipes (01889 271818)......
good to work with, but the 'S' stands for stainless, so won't be cheap-as-chips
Jiff
Posted 09 November 2015 - 09:35 am
Lots of pipe bends and flared ends available at auto jumbles such as the CNash ones at Stafford (or ebay), if you aren't in a hurry. You can cut them up to suit your needs and take them to your local fab shop for welding.
Not much help but you may find something here >
Southern Classic Off Road Show & Jumble
Kempton Park, Staines Road East, Sunbury on Thames, Middlesex, TW16 5AQ.
Posted 14 November 2015 - 05:15 pm
Hi Ali,
Try Geoff Madden at ASBO Exhausts. He made me a 2 into 1 for the 900 using just the front pipes and made everything else including tri-oval slip on. The work was excellent and all fitted well. Cost? £160 but that was 4 years ago.
Phone him on 07930306009 He is in Lancashire but that problem isn't insurmountable.
Good Luck,
F.C.
