new owner
Posted 04 September 2006 - 04:28 pm
Posted 04 September 2006 - 04:38 pm
Posted 04 September 2006 - 04:47 pm
welcome tone
dunno bout the er pressures, sure someone will be along shortly to help
Posted 04 September 2006 - 05:04 pm
Posted 04 September 2006 - 05:33 pm
Welcome.
Those pressures are most likely too low. One of the 900 bhoys will probably be along to give ya exact pressures. I run 29psi front and 36psi rear on me 850.
#6 Guest_E.T._*
Posted 04 September 2006 - 05:37 pm
I'd check the tyre manufacturers website rather than rely on the service guide. Metzeler recommend higher pressures in their Z6 tyres than the service guide gives - and I think it varies from type to type.
#9 Guest_Mungas_*
Posted 04 September 2006 - 07:45 pm
gleetings dude
bridgestone 20's
35psi fr
42psi rear (may knock that down a couple of psi's)
sayanora
flom chickenchowman...
Posted 04 September 2006 - 07:58 pm
Posted 04 September 2006 - 08:03 pm
I've got Avon Azaros, 34 front 40 rear.
Johnny W
Posted 05 September 2006 - 01:15 am
Mine says 29 and 36. with the 900s they did vary the front pressure when they changed the spring rates in the forks, they lowere the recommended pressure when they raised the spring rate. 2003 should be the firmer springs.
Al
Posted 05 September 2006 - 11:12 am
I run Metzler Z6s at 34f and 38r
Ditto Dandy's settings here.
ohh and they are the pressures I use when i try to remove the elphants . meeself and dandy are roughly the same weight, so that probably explains the same settings.
*cough* 13 1/2 stone *cough* if that helps at all
Posted 05 September 2006 - 11:27 am
somewhere near though ehh
#16
Posted 05 September 2006 - 11:59 am
#17
Posted 05 September 2006 - 04:06 pm
is that WITH or WITHOUT your gear on ????????????
#18 Guest_E.T._*
Posted 05 September 2006 - 07:53 pm
I weigh 70kg BTW
#19
Posted 05 September 2006 - 08:36 pm
I weigh 70kg BTW
That's pretty hard. Prescribed pressures for 1up of average weight are 2.25 bar front and 2.5 bar rear.
Although I must admit I use 2.4 and 2,8 myself
#20 Guest_Mungas_*
Posted 05 September 2006 - 09:57 pm
hey sum
96 onwards
not in my owner manual front 2.25 bar
rear 2.75 bar
haynes book of lies front 33 psi
(all load/speeds)
rear 40 psi
but yours is a lot newer. 91-95 models have lower fr/28psi r/33psi....depends on he tyers too i suppose.
