DIY Fuel injection on a mk1?
Posted 11 January 2008 - 06:28 pm
I've been having serious trouble with my bike's running in the cold. It seems to be flooding, and does not get to warm operation temperature, unless sat idling in traffic for about 5 minutes without moving. And even then, it doesn't idle properly.
I would like to look into fitting fuel injection to my bike. My old man's 900 is great in any weather/ at all altitudes, and has excellent fuel economy. I just want a simple system that would run off a throttle position sensor, and rev meter (crank position sensor), and a simple ecu to control injectors and spark.
Anybody done any research on this, or know how feasable it is? Or how I could sort my horrible fuelling, and sort my economy out?
Tyler
Posted 11 January 2008 - 09:02 pm
Much cheaper than building an FI system from scratch.
Posted 11 January 2008 - 09:05 pm
Where are you?
Posted 11 January 2008 - 09:06 pm
Where are you?
Tony !
Posted 12 January 2008 - 12:03 am
Then I usually wake up. (sorry, no offense intended)
The electronics involved is not exactly rocket science, there are loads of really cheap programmable microprocessors out there, more than capable of doing real time engine management for a 2-cylinder, 12k RPM max engine, and it only takes a few thousand lines of code to do it.
The mechanical part is another matter - I don't think it's even possible to build a DIY FI system. Nor would it be feasible in fact, since it would be much cheaper to just buy the parts from a breakers. I'm not exactly up-to-date on the prices here, but I would venture a guess that it would be several hundred quid for the lot (FI fuel pump, throttle bodies, TPS sensors, etc).
Now for the really difficult part: you would need loads of time with some rather expensive electronics equipment (such as a digital oscilloscope) and a dyno, plus a means of changing/controlling the composition, pressure and temperature of the intake air. I guess that unless you own (or have unlimited access to) an engine tuning shop, for the money you would spend on this you could easily buy a few (FI) bikes.
Posted 12 January 2008 - 02:13 am
Where are you?
oh dear
looks like your going for the carpe most usefull poster of 2008 comp......598 posts,,, 570 saying "where are you" ,,, dont think thats gonna win it
Posted 12 January 2008 - 10:25 am
That's not my experience; cold-starts and high speed fueling may be better but even modern FIs can be jerky and snatchy, and sometimes respond rather temperamental on half-hearted twists of the throttle. Carbs may be less accurate in theory but still can't be beaten when it comes to smoothness.
And these are engine-specifically developed factory systems, it's unlikely to improve on that by sticking on some FI-bits that a breaker has lying around
Why not just fix the cause of the problem rather than dismissing the concept of carburettors altogether?
Edited by robelst, 12 January 2008 - 10:56 am.
Posted 12 January 2008 - 04:23 pm
nor is it the experience of those having had a blast on both the 950 (carbed and very smooth) and the 990 (injected yand very twitchy) KTM adventure. Not sure the difference isn't just due to a lousy FI setup by KTM but the difference is quite astonishing.
Posted 12 January 2008 - 05:04 pm
Posted 12 January 2008 - 05:41 pm
Agreed, you could wind up with a 500 pound paperweight.
Posted 12 January 2008 - 06:34 pm
Now, I know that there have been (and still are) some really crappy FI systems on several motorcycles, particularly on their first versions - Honda Varadero, KTM 950/990 Adventure to name some well-known screw-ups. On the other hand, if you are not bound by the same time and mass-production economy issues as a big company, you can always come with a (much) better tuning, if you put enough work into it. Think about how many engine tuning shops there are, and they improve on the factory thing - even if none are anywhere near the factory budget.
Posted 12 January 2008 - 06:56 pm
Posted 12 January 2008 - 08:09 pm
......unless you are an electronics guru leave it well alone on a mk1/3VD
the 900 FI system can be pretty much bolted onto the mk2 4TX engine (as shown by the tutorial on the TRX site)
http://trx850.motoma...opic.php?t=2022
but because of the wide variety of parts required the cost of the 900 parts is more than the value of the 850 bike
basically its a full electrics transplant, you also need some of the sender sensor thingys out the engine
apparently the 3VD engine doesnt have the case holes/mods (but i dont have all the details on this)
if you really want to do this to a 4TX buy a crashed damaged 900 and rip its guts out
if you are prepared to wait a little (could be 12months away) there is possibly going to be a DIY kit produced by raidxtreme (see superten xtz site for info)
http://supertenere.proboards20.com/
not sure i agree on the better bit, but i agree with the rest, if u want a fuel injected TDM, buy a 900
a decent 2nd hand bike is under £3k
or you can pick at cat C up for under a grand, plastics & the like will cost you another few hundred
Posted 12 January 2008 - 10:34 pm
Yet, if it somehow I would stumble upon a treasure chest in front of my door tomorrow morning (mind you that it would take a very big chest, as over here the state would steal the better part of it right away and tax the rest), anyway, if that would happen, I would start building all kinds of crazy (and utterly impractical) stuff like this the next day.
A DIY FI system is particularly appealing to me, since it involves two things I love: motorcycles and programming. The latter being my full-time job, and I still remember when I started learning it, on a communist Z80-clone 8 bit processor, writing programs by hand directly into the memory (remember POKE/PEEK, anyone?).
Posted 13 January 2008 - 05:25 pm
#16
Posted 13 January 2008 - 08:56 pm
Luxury. I remember writing programs in FORTRAN directly onto IBM punched cards. What fun we had when we dropped the stack of cards and had to sort them out.
#17
Posted 14 January 2008 - 01:20 am
We had a card punch at school, wrote the programs in 'CESIL', and posted the cards to an office in Croydon where they had a mainframe with a card reader. After waiting excitedly, about a week later, the results were posted back on a stripey sheet of paper...."Syntax error, line 20"
I guess computers have moved on a fair bit really.
#18
Posted 14 January 2008 - 08:54 am
#19
Posted 14 January 2008 - 10:54 am
and 1 card out of sequence.... error error
#20
Posted 14 January 2008 - 11:35 am
I guess it was before the war.
The Civil War I mean...
