Anyone Elses 9Er Do This?
13 replies to this topic
#1 Lightning
Lightning
  • 127 posts
Posted 10 August 2022 - 07:05 am
To avoid annoying the neighbors (extra early starts in hot weather) I've been firing up the tdm and trying to make a getaway without sitting idling but I've noticed the old girl don't like it, seems to fart and spit a bit if you try pulling away if you don't give her a minute to compose herself, bit like mixture isn't right but I understand this is controlled by the ECU.
Is this normal or indicative of a looming issue? Runs sweet as a nut otherwise. The fast start mechanism is working fine.
For where your treasure is, there will your heart be also.
#2 Snowbird
  • 1,359 posts
Posted 10 August 2022 - 07:41 am
It's always gonna be better to let it run for a minute to get the oil round, I think most engines will splutter a bit pulling straight away from a cold start, oil works better when warm too.
#3 fixitsan
  • 4,676 posts
Posted 10 August 2022 - 07:46 am
Assuming all service items are up to date, plugs are recent and the plug leads and caps aren't leaking, you could try fitting increasingly louder exhaust until you find the 'complaint level'. Once established, you just need to dial it back from there and enjoy the TDM :)
#4 leehenty
  • 5,090 posts
Posted 10 August 2022 - 08:21 am
Mine does this and stops if you try to go too soon from dead cold. 30 seconds of fast idle she's happy
#5 Rallyist
  • 3,253 posts
Posted 10 August 2022 - 08:31 am
Mine also
#6 Lightning
Lightning
  • 127 posts
Posted 10 August 2022 - 08:50 am
Ooooo eeeeeee this is good news. The locals will just have to enjoy the tdm sound for a while...still running the stock cans so I shouldn't worry really!!!
#7 poppykle
poppykle
  • 83 posts
Posted 18 August 2022 - 06:02 am
I let mine idle just long enough to get the helmet and gloves on.  Never a problem riding off.
#8 TKH
Posted 23 August 2022 - 12:51 pm
Mine too. Don't know why though.
#9 Coxylaad
Coxylaad
  • 509 posts
Posted 25 August 2022 - 09:27 am
probably the cold start mechanism playing up.
Im seriously considering ditching mine altogether and fitting a set of BMW F800 throttle bodies.
#10 Lightning
Lightning
  • 127 posts
Posted 25 August 2022 - 11:33 am
I do believe it is linked to the cold start mechanism. Although it's doing what its supposed to (I've just had it off and cleaned it as it was seized) if I push the mechanism manually to the warm position and hold it there it revs a lot more cleanly in neutral. Maybe that's just the way it is, I guess the fi on these is pretty basic compared to today's stuff.
Edited by Tdmnomore, 25 August 2022 - 11:34 am.
#11 Studley Ramrod
  • 19,214 posts
Posted 29 August 2022 - 05:33 pm
Pray tell, why F800 throttle bodies ?
#12 Coxylaad
Coxylaad
  • 509 posts
Posted 30 August 2022 - 02:57 pm
Because they are the same spacing give or take a couple of mm, and they are 42mm and will breathe better
#13 Tor
Tor
  • 71 posts
Posted 19 September 2022 - 10:50 am
Mine runs clean from the get-go, also in below-zero temperatures, regardless of cans. Has kept doing so before and after plugs, air filter change.
#14 fixitsan
  • 4,676 posts
Posted 20 September 2022 - 09:40 pm
I've managed to encourage mine to do this, by setting the idle RPM on the CSM to about 1900. When I dropped it back to 1500 RPM it works fine again.
