Good Chain And Sprocket Combo
8 replies to this topic
#1 vanjka
vanjka
  • 14 posts
Posted 24 January 2020 - 02:52 am
Hello TDM'rs,
It has come that time to change my chain and sprockets since I do not ride this bike as often as I should and the chain looks a bit rusty. Any suggestions on what should I buy. Please give me the sizes/specs so I can go shopping.
Thank you in advance.
Vanjka  :good:
#2 leehenty
  • 5,083 posts
Posted 24 January 2020 - 09:38 am
Need to know model of TDM, but Afam sprockets are good quality.
#3 drewpy
  • 1,757 posts
Posted 24 January 2020 - 12:19 pm
I second Afam. I got the gold X ring chain and Afam sprockets
#4 Favs
  • 4,394 posts
Posted 24 January 2020 - 04:19 pm
D.I.D 520 chain 118 links
Ognibene or AFAM sprockets
#5 leehenty
  • 5,083 posts
Posted 24 January 2020 - 06:52 pm
TDM 900 is 525 chain not sure about 850's
#6 Favs
  • 4,394 posts
Posted 24 January 2020 - 08:23 pm
Tis indeed 525
#7 wicklamulla
Posted 25 January 2020 - 10:55 pm
there used to be a company offering an upgrade kit to fit a 530 chain.  twas a fair few years back and i ferget the details now.
#8 vanjka
vanjka
  • 14 posts
Posted 26 January 2020 - 01:44 am
Thank you peeps sorry mine is 2009 non ABS  :huh:
#9 leehenty
  • 5,083 posts
Posted 26 January 2020 - 02:47 pm
Here ya go.
https://www.biketorq.../01286636-7.htm
For the best durability I would go for is this.
https://www.biketorq.../01286636-8.htm
Edited by leehenty, 26 January 2020 - 02:49 pm.
