Xt1200 Headlight Bulb - Keeps Blowing
12 replies to this topic
#1 dmmsta
dmmsta
  • 3,627 posts
Posted 21 September 2018 - 09:23 am
I've replaced 6 or 7 bulbs in the headlight on my S10 since April when I got it.
I happens randomly
It isn't LH/RH specific, but I think that once one goes (and is replaced) then other side goes
I've tried cheap & cheerful bulbs, I've tried Osram Night Racer 110 bulbs.
Can anyone with a little more knowledge of the electrickery substance offer any tip for investigation...before you ask I have tried to lick it but it made no difference...
#2 dapleb
  • 18,117 posts
Posted 21 September 2018 - 11:36 am
You could try l. ... EDIT I see you already tried that. Good luck dmmmnm
#3 dmmsta
dmmsta
  • 3,627 posts
Posted 21 September 2018 - 11:43 am
:rotflmmfao:
#4 Apache
Apache
  • 553 posts
Posted 21 September 2018 - 12:59 pm
Do the bulbs turn black or does the filament break ?
#5 dmmsta
dmmsta
  • 3,627 posts
Posted 21 September 2018 - 01:40 pm
Filament breaks...
#6 Apache
Apache
  • 553 posts
Posted 21 September 2018 - 01:56 pm
Fine vibration. Check all fasteners around the front end. Not necessarily at the headlight area only. Could be wheel balance too that you can't feel but will still crack bulb filament. Hth
#7 dmmsta
dmmsta
  • 3,627 posts
Posted 21 September 2018 - 02:46 pm
All input is of benefit!
#8 TKH
Posted 21 September 2018 - 07:15 pm
I realise bad earth would usually result in a blackened bulb but maybe worth checking? Also the relay? What rating is the fuse for the lights? Has it been changed in the past (previous owner) and is now to high a rating?
#9 Favs
  • 4,395 posts
Posted 22 September 2018 - 09:20 am
+1 vibes
If no vibe problems;
I'm sure you know +% super lamps have a short life often less than 150 hours even when fitted to relatively vibration-free cars
Cheap lamps - says it all.
Try buying a standard output  lamp of a high quality, Osram also do a longlife version H7, (these lamps are same STD wattage but stronger filament = not quite as bright), or visit your local VAG shop and buy STD from them (cheaper than Halfrauds and good quality too)
Longlife Osram (cheaper may be available ) https://www.ebay.co....HHVnRui-AeqtRSw
If you bike is overcharging it will blow the filament - worth checking the battery isn't being cooked too (thinking of an XL125 & a Goldwing Mk1 which did this)
HTH
#10 hallrob1
hallrob1
  • 1,098 posts
Posted 28 September 2018 - 07:26 am
Osram do a bike specific uprated bulb Night Racer;
https://ebay.us/c72YGe
My niner used to blow bulbs about every 6 months so I put one of these in (I think mine was +110 brightness, I know they do one) and I'm just coming up to 6 months so lets see.
Supposedly it deals with the vibration better, which I'm guessing could be worse on a 1200 twin?
#11 dapleb
  • 18,117 posts
Posted 28 September 2018 - 09:02 am
Sounds loike the dmmmmm has tried them already wob
#12 Favs
  • 4,395 posts
Posted 28 September 2018 - 11:09 am
Poundland H7 (car)  less than a tankful & popped.
#13 TKH
Posted 29 September 2018 - 09:49 am
Try the owners club and see if it's a known problem with a known solution?
