#tdm3Vd900Project
76 replies to this topic
#1 Medmonic
Medmonic
  • 81 posts
Posted 29 November 2020 - 10:34 am
Hello again ,
After several months without  no news , started again  a new engine rebuild .
For this new project i needed :
1 engine donor  from tdm 900 5ps
1 gearbox from tdm  850 4tx
 1 engine from tdm 850 3vd
so after several months i got my hands on a tdm 900 engine 5ps for parts , found a gearbox from tdm 850 4tx , and regarding  the 3vd engine already had several engines at home .
First part of the project was disassemble the 900 engine to see  parts i could use on the project .Apart of the cylinder bloc plus the pistons , manage to use water pump , both oils pumps , oil sump ( its deeper than a 850  sump ) so more oil available in the sump , both connecting rods since they have a larger piston pins.
Since the TDM 900 cylinder bloc is bigger than the 850 i had to machine the upper crankcase to match the new  cylinder bloc.
 So the first step was to machine the upper crankcase
Attached File  IMG_20201104_164544.jpg   164.57KB   2 downloadsAttached File  IMG_20201105_114624.jpg   269.04KB   1 downloads
#2 dablik
  • 10,747 posts
Posted 29 November 2020 - 10:52 am
This will be interesting to follow, keep posting Medmonic  :good:
#3 Snowbird
  • 1,354 posts
Posted 29 November 2020 - 10:58 am
A project to watch for sure, good luck Medmonic, keep on with the updates.
I assume the complete 900 lump can't be made to fit then?
#4 Medmonic
Medmonic
  • 81 posts
Posted 29 November 2020 - 01:57 pm
nop....there are a lot differences included electronic .....
i will cheers !!
#5 fixitsan
  • 4,671 posts
Posted 29 November 2020 - 02:41 pm
Is that only the main reason ?  Will it physically fit ? You can wipe out most of the electronic/fuel injection issues just by converting to gravity feed carbs. Finding an aftermarket ignition system which will be able to be used doesn't seem too difficult either
#6 Medmonic
Medmonic
  • 81 posts
Posted 29 November 2020 - 04:31 pm
for me there are a lost of differences , one is the engine supports , the other is the crankshaft ,on engine 5ps 900 is at 270 degrees and the 3vd is at 360 degrees , my main goal here is to have the engine running at 360 degrees .
#7 Snowbird
  • 1,354 posts
Posted 29 November 2020 - 04:57 pm
Is the stroke the same on the 9er?
#8 fixitsan
  • 4,671 posts
Posted 29 November 2020 - 05:20 pm
Okay. We've seen it done before, a 900 engine in a frame designed for the 850. (might have been a TRX but the same engine essentiallyly)....it seemed to only need some upper mounting adapter plates making, which i think you can have cut from a laser cutting service.
#9 Pedro
Pedro
  • 266 posts
Posted 29 November 2020 - 07:44 pm
This should be interesting!!  Keep posting the build, please.
PS, if you have that many 3vd engines, would you have a good spare conrod you're willing to sell?  :rolleyes:
Cheers,
Pedro
#10 Studley Ramrod
  • 19,213 posts
Posted 30 November 2020 - 01:17 pm
Interesting. :munching_out:
Did you calculate the compression ratio before having the upper crankcase machined ?
#11 dapleb
  • 18,114 posts
Posted 30 November 2020 - 02:50 pm
I think Emmett and Ric machined the barrels rather than case. Hmm not sure of benefits of otherwise of either.
#12 Medmonic
Medmonic
  • 81 posts
Posted 30 November 2020 - 09:35 pm
todays work was to install the barrels , just to find that the head gasket from the 850 will not fit on this engine , i need 900 head gasket ......shiiiiit !! new head gasket on the way , until there iam holding the horses ......Attached File  IMG_20201130_215442_078.jpg   123.59KB   1 downloadsAttached File  IMG_20201130_215442_077.jpg   100.96KB   0 downloadsAttached File  IMG_20201130_130124.jpg   153.98KB   0 downloadsAttached File  IMG_20201130_125333.jpg   206.38KB   0 downloadsAttached File  IMG_20201130_125408.jpg   117.11KB   0 downloads
by my calculation yes ..
#13 Medmonic
Medmonic
  • 81 posts
Posted 30 November 2020 - 09:45 pm
i am thinking in a project similar , frame TRX and a complet swap from a tdm 900 .......but trx frames are ard to find .........
#14 dapleb
  • 18,114 posts
Posted 30 November 2020 - 09:46 pm
Any more details of your machining plz medmon while you are waiting for gasketo
#15 Medmonic
Medmonic
  • 81 posts
Posted 30 November 2020 - 09:48 pm
Cheers,
Pedro
dont worry , i have a lot of pictures and details ....
#16 dandywarhol
Posted 30 November 2020 - 09:49 pm
Coxxxylad transplanted a 900 into his TRX frame. He also transplanted an MT09 into a TRX
#17 Medmonic
Medmonic
  • 81 posts
Posted 30 November 2020 - 09:57 pm
Cheers,
Pedro
wich color you want ???hahahaaah  !!let me know what you need and i will ship to you ..
i machine the case , because in the 900 engine its the case that is machined , the barrels dont have a lot of room to be machined ...
were i machined the upper case , dont  mess  with the compression ratio , i just machined around the space were the barrels enter
were i can fin is projects ?
#18 Studley Ramrod
  • 19,213 posts
Posted 01 December 2020 - 05:06 pm
http://dashack.co.uk...4fcbv0hcf18bvdh
Just look at coxxxxylad's topics. :)
There was one guy who fitted the 900 engine into a mk1 850
http://www.carpe-tdm...900#entry136376
#19 dandywarhol
Posted 02 December 2020 - 06:18 pm
http://www.trx850.co...ewforum.php?f=5
#20 Medmonic
Medmonic
  • 81 posts
Posted 08 December 2020 - 09:00 pm
Well lately internet at home has being a big issue , cant upload any photos ....welcome to France ......
Meanwhile i had some work to do in the head before install in the engine , the ideia was to increase air and exhaust flow due to bigger pistons ...
Attached File  IMG_20201123_104926.jpg   152.23KB   0 downloads
Attached File  IMG_20201123_104949.jpg   132.71KB   0 downloads
after that the normal servicing , clean the head , change the seals and lapping the valves
Attached File  IMG_20201123_105005.jpg   125.83KB   0 downloads
Attached File  IMG_20201125_122136.jpg   159.53KB   0 downloads
And finally everything  is ready to assemble .....
Attached File  IMG_20201125_115355.jpg   132.55KB   0 downloads
