Mk2A Carbs On A Mk1
105 replies to this topic
#21 Studley Ramrod
  • 19,213 posts
Posted 20 September 2020 - 02:11 pm
No line on the float bowl on mk2a carbs Dabs. A conflab with Obi wan Kinobe is needed to adjust the fuel levels. :lol:
#22 dablik
  • 10,747 posts
Posted 20 September 2020 - 05:00 pm
There is a line buddy, just not in the usual place, YZF1000 Thunderace use the same carbs and i've downloaded a PDF which shows how to set the fuel height, also found a video where it's done the same way.. also the TA carb kits should fit if needed, dunno about mulsion tubes though if that should become necessary..
I've swung for a set from GNMoto along with an air box, saw a video of the bike running before dismantling so fingers crossed i can wup em on without drama, figured it was only money i did'nt spend on petrol in the end..
Also re-fixed the leak on me float bowl again so they'll do as back up..
This is the video but you need to fast forward a bit..
#23 dapleb
  • 18,114 posts
Posted 20 September 2020 - 05:38 pm
Lolzio. Entertaining vid that..and perfectly illustrates why I have always used float height to adjust.
#24 Studley Ramrod
  • 19,213 posts
Posted 20 September 2020 - 06:47 pm
Yeah, perhaps I should have elaborated.  The measurement for the mk2a carbs as given in the Haynes has no bearing on any markings on the float bowls.  Hence no measurement to use as a guide.
Good find with the thunderace PDF though. :good:  Be great if the measurements are useable on the mk2a carbs and deffo worth putting in KB if they are.
#25 Studley Ramrod
  • 19,213 posts
Posted 20 September 2020 - 06:57 pm
But do you know what the float height is for mk2a carbs ?
#26 MickC
MickC
  • 408 posts
Posted 20 September 2020 - 07:25 pm
When I give a set of carbs a clean out I spray carb cleaner through the various orifices then use an air line dont adjust feck all put them on and see what happens because I do believe you can get too involved in setting things up spot on and you can feck it up and you wont know if it was you or the carbs were shoite to start with.
so get some MK2a carbs clean em and put them on if shoite take them off and feck about.
I have a set of vacume gauges that I got when I had a Z1000J spent ages getting them equal but when I stopped bothering the thing still ran fine so I just do the simple things in life now try it and see.
#27 dablik
  • 10,747 posts
Posted 20 September 2020 - 08:25 pm
Righto Mick while reading Studleys post that's the same conclusion i came to, i'll do likewise then..
Surely somebody has had to check fuel levels on a mk2a at some point ! or is it try and try again ??
Edited by dablik, 20 September 2020 - 08:35 pm.
#28 dablik
  • 10,747 posts
Posted 20 September 2020 - 08:35 pm
No dont know that, struggling to find any info furrit.....bassads.
#29 Snowbird
  • 1,354 posts
Posted 20 September 2020 - 08:37 pm
Do the carbs sit at the same angle on the thunderace? Would make a difference to the fuel height required.
#30 dablik
  • 10,747 posts
Posted 20 September 2020 - 08:38 pm
Dont think so Dave as the fuel levels given for both bikes are different.....be good to find a thunderace someplace to measure the angle.
#31 dablik
  • 10,747 posts
Posted 21 September 2020 - 12:01 pm
But fuel levels are near enough between T.A and Mk2a (Haynes gives a smaller level)  JBX and the Mk2a supplementary manual both quote below figure for Mk2a.
T.A ---  4.1-5.1
Mk2a-  4.4-5.4
Re syncing carbs, assume mk2a has hoses off each carb as it has an lekky fool pump.
Edited by dablik, 21 September 2020 - 01:10 pm.
#32 Studley Ramrod
  • 19,213 posts
Posted 21 September 2020 - 02:40 pm
Mk2a bike has blanked out hoses running off the inlet stubs.  Soooo, syncing mk2a carbs on a mk1 would be same as doing the mk1.
Seem to remember having no problems with mk2a carbs at all once I'd syced them so I doubt you'd need to alter fuel levels unless someone's been in there before you and messed things up.  Brass choke plungers, better modified sliders, brass float needle housing, all stuff much more robust on mk2a carbs. :)
I'd fit 'em on my mk1 if I had the desire to spend some money on it. :lol:
#33 dablik
  • 10,747 posts
Posted 21 September 2020 - 04:28 pm
Yea not gonna fiddle with them, a quick clean and fit them, i'll check fuel level once on and just for grins iffin there okay i might measure float height then, be good to know, but maybe not!!!!
Edit..They went on sale Saturday and seen the vid of bike running just before they pulled them, so hoping all is good..
Edited by dablik, 21 September 2020 - 04:29 pm.
#34 Bjørge
  • 1,791 posts
Posted 21 September 2020 - 06:08 pm
Just bought a set of Mk2a carbs on ebay, just need an air filter box and choke wire to go with it. Getting tired of this carb fettlin' 😁
#35 dablik
  • 10,747 posts
Posted 22 September 2020 - 04:22 pm
I'm sure MickC mentioned using the existing choke cable Bjorge ?
#36 Bjørge
  • 1,791 posts
Posted 23 September 2020 - 07:13 am
You're right! I misread that line  :P . Thanks, saved me a few $/£/€ !
#37 MickC
MickC
  • 408 posts
Posted 24 September 2020 - 03:57 pm
Yeah choke cable starts in a different place but attaches on carb the same way.......Got to say though my choke wont stay pulled out so baisically hold ot out to start give it like 10 secs (not timed it) then let go and it drops back in,dont know if i have a problem somewhere but dosent bother me,i think it is an old cable so maybe just a bit tired.
#38 Bjørge
  • 1,791 posts
Posted 24 September 2020 - 04:43 pm
I had a problem with the choke not going off when knob is pushed back, added a coupla springs to make it act like yours 😎
#39 Studley Ramrod
  • 19,213 posts
Posted 24 September 2020 - 05:40 pm
Mine's the same, can't be arsed to sort it. :lol:
#40 dapleb
  • 18,114 posts
Posted 24 September 2020 - 06:22 pm
Snap... Mine used to be pull out and twist to hold that choke setting... Now it needs to be held out man Welly
