Neutral Switch Test?
5 replies to this topic
#1 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 10 December 2019 - 06:54 pm
Hi guys, if the neutral switch that is in the engine is playing up, would the little green light still be on, and how can I test the switch please....regards.
#2 wicklamulla
Posted 11 December 2019 - 12:48 am
can ya describe what is happening or what the problem appears to be?
#3 Bjørge
  • 1,791 posts
Posted 12 December 2019 - 08:46 am
If the switch or the wire were broken, or the bulb were broken, there would be no green light. Okay, a slight possibility of a short circuit - in that case it would be allways on.
#4 leehenty
  • 5,085 posts
Posted 12 December 2019 - 08:53 am
Generally the type of switch it is, wears out and eventually goes intermittent open circuit. It's a ball in the end of the change drum contacting a brass pin in plastic. Look at JBX TDM for his gear indicator based on the same switch.
#5 TKH
Posted 12 December 2019 - 01:11 pm
Mine sometimes doesn't come on. This also means I have to start the bike with the clutch pulled in.
#6 dablik
  • 10,747 posts
Posted 12 December 2019 - 10:15 pm
You can take the switch apart if needed, i've done this to repair a broken wire..
