Yamaha Tdr 125
11 replies to this topic
#1 dapleb
  • 18,114 posts
Posted 13 December 2019 - 08:58 pm
Anyone know oubt about em? One of Tishabelles brudders found one and is thunkin of buying.
I will be on tyre kicking duties.
#2 leehenty
  • 5,085 posts
Posted 13 December 2019 - 11:44 pm
water cooled two smoke with a electric powervalve thingy afaik. usual suspects can be rattliing at cold start and lack of compression, they like nice expensive two stroke oil.
really easy to fix provided the crank is ok. Various parts are available to take them up to about 170cc, check the power valve moves properly they often stick.
Edited by leehenty, 13 December 2019 - 11:47 pm.
#3 wicklamulla
Posted 14 December 2019 - 09:27 am
ya may be able to fit a 225cc kit to them.  The are very 3VD looking and i reckon they are a great looking bike. I reckon ya cud slot an XT600 lump in there as thas what Yamaha shudda done back in the day!
#4 Catteeclan
  • 2,440 posts
Posted 14 December 2019 - 12:35 pm
If you're expecting the same reliability of a 4 stroke run away but there's loads of fun to had with the power band. Long time ago I rode one although I rebuilt the top end twice on the DT, same engine I believe.
#5 dapleb
  • 18,114 posts
Posted 14 December 2019 - 12:42 pm
I did wonder if it was the same enjun as the TZR. Had Juan of them with the servo controlled power band and that was ace fun.
#6 wicklamulla
Posted 14 December 2019 - 10:38 pm
  same enjun i tink,  decent oil will prolong any 2T unit.
#7 Studley Ramrod
  • 19,213 posts
Posted 15 December 2019 - 05:41 pm
Apparently, there's the 15hp and the 28hp versions. The 28hp version being a very on-off affair regarding the powerband.  Great frame design and capable of 55mpg. :lol:
#8 wicklamulla
Posted 15 December 2019 - 10:50 pm
if it's like the TZR125 then the restriction is fairly easy to remove by rotating the YPVS thingamajic around and removing a washer in the downpoipe.
#9 JMC
JMC
  • 257 posts
Posted 16 December 2019 - 09:10 pm
Bloody hell not seen one of them in years spent my teenage years blowin them up  :rotflmmfao:  along with the good old kmx125, mtx125 and ts125, aprillia sport pro 125, rg250, nsr125 holy christ I blew up everything I had back then ffs, spent many a night replacing piston and rings in my mothers kitchen with the bike in bits on the floor and she never complained once, I suppose she was happy knowing I spent everything on bikes and not on drink and drugs.
Anyhoo if the engine is in good nick buy it everything else can be made good, love the old 2 smokes  :good:
Hunter S. Thompson.
#10 harvey krumpet
harvey krumpet
  • 2,050 posts
Posted 17 December 2019 - 08:10 pm
Lol. Parallel lives.
If the TDR tiddler is a DT engine then it would be feasible to slot a DT 230 or WR 200 motor in it. All the same family.Our DT 230 is allegedly over 40hp, it goes like a cut cat.
As said above, it's the bottom end of the motor and power valves that need to be checked. Should be loads of parts available.
I had my DT 230 re-built after drowning it in a creek, parts for top and bottom end, bearings, seals, piston kit ect was about $800 NZ, from Japan.
The motors are reliable with good maintenance but running quite lean on the auto oiler and stock jetting don't like top speed testing on motorways.Bigger main jet helps flow more fuel to keep the piston crown cooler.
#11 Catteeclan
  • 2,440 posts
Posted 17 December 2019 - 08:14 pm
Agreed, bit more fuel will lose a little top end but lasts longer, unless you're gonna rag the pants of it.  :lol:
#12 harvey krumpet
harvey krumpet
  • 2,050 posts
Posted 18 December 2019 - 07:59 pm
They do encourage you to rag their pants off.... Riding a  2t on twisty roads is a rare pleasure nowadays.
