Hows Your U?
22 replies to this topic
#1 jiff
jiff
  • 688 posts
Posted 10 April 2011 - 01:58 pm
.............feeling in need of some low-speed practice, I trolled out this morning to a sun-drenched but un-populated local car park, to try out some manoevres, and hopefully, polish my anti-wobble strategies.
I was trying out some recently acquired gems of advice relating to low-speed techniques.........'back brake & clutch only'..........'2500 revs'....etc.......... all of which felt much more effective and stable....... then I started to address the effectiveness of my U-turn technique.
It all felt great, & was working just as well as I'd hoped................EXCEPT.............I can't seem to tighten my turn to anything less than a diameter of about 30 feet.
This seems pretty feeble to me............& I'd be interested to know how it compares with how y'all do............could it be down to my short arms ? !!!
.........so I guess y'all will be out there this afternoon with a tape measure, checking it out
...................Jiff
#2 celticbiker
celticbiker
  • 1,726 posts
Posted 10 April 2011 - 02:52 pm
About 12 ft diameter regular, 9-10 ft ish really trying.
#3 JollyGiant
Posted 10 April 2011 - 03:29 pm
Here's how you do it...
Linky Dinky Doo Doo Dah Dah
#4 Gobsheen
Gobsheen
  • 88 posts
Posted 10 April 2011 - 06:14 pm
About 12-ish feet sounds right........like you do for the bike test. Can't say I've ever been that confident at u-turns. Could probably do with some practice myself. If it helps, this what I remember from my test training.
- Look where you want the bike to go, not straight in front of the bike or at the kerb etc. So, you're looking right over your shoulder to start with, assuming to road is clear.
- I was taught to have the revs pretty high for the whole manoeuvre, about 3500-4000rpm. Felt like the bike was screaming for such a slow speed but he told me to just ignore it. That set the throttle in one position for the whole thing so you could forget about it. Then, get moving straight ahead with the clutch held well into the biting point. Again, hold the clutch there for the rest of the u-turn. Now, slow the bike back a bit with the rear brake and round you go. Only adjust the rear brake until you straighten up on the other side.
- You don't have to lean into the turn at all....just steer it.
Maybe you've tried that stuff before. A friend who took his test a few months after me was taught a completely different way......lower revs and adjust speed with the clutch, which sounds a lot more simple. I'd say we were both at pretty similar levels of riding ability. We showed each other how we were taught and my turns looked way more controlled and consistent.
Try this in your carpark..........................Video
Edited by Gobsheen, 10 April 2011 - 06:19 pm.
#5 ChrisG
  • 8,276 posts
Posted 11 April 2011 - 07:50 am
Not had a go on the 900 yet but I can hit the steering stops on the Mk1. It is well worth spending a bit of time practicing in a carpark like that, amazing what it can do for your low speed confidence.
#6 trevini
trevini
  • 1,783 posts
Posted 11 April 2011 - 09:34 am
Lock stops in both directions here.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy,  Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators   Currently not fitted - PC3, Remus Revolutions.
#7 TonyDevil
Posted 11 April 2011 - 10:12 am
lockstop here too, but i will admit i consider plastics to be too expensive to worry what people think of feet out u-turns laugh.gif
its much easier on the mk1 than the 900 due to carbs v FI
#8 Nog
Nog
  • 514 posts
Posted 11 April 2011 - 10:50 am
QUOTE(TonyDevil @ Mon 11th Apr 2011, 11:12 AM) <{POST_SNAPBACK}>
+1
Although if you want to look cooler, footdown, lock front brake, spin rear and slide back end round wink.gif
#9 JollyGiant
Posted 11 April 2011 - 11:00 am
Lockstops here too but since they are T/Ace ones and awfully shite it easier to run the Exxon Valdez round in a bath with a Blue whale in one end!!!
#10 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 11 April 2011 - 11:34 am
the easiest way to do it:
- look over your shoulder to where you want to go (as far as possible)
- keep revs up (the rotation will help balance the bike) and constant
- slow down using rear brake
- speed up using clutch
- Keep body as straight as possible and push the bike down away from you (like in picture below, this will make the turning circle smaller. Do not use this technique for high speed cornering)
oh, and did I mention looking where you want to go is important?
http://pix.pixagogo.com/S5!!1S2Llq...gymkhana062.jpg
Yamaha XJ600S Diversion '94
Yamaha XJ900S Diversion '97
Suzuki SV650S '01
Yamaha TDM900 '04
#11 crispy
crispy
  • 212 posts
Posted 11 April 2011 - 02:55 pm
QUOTE(duibhce Kaelann @ Mon 11th Apr 2011, 12:34 PM) <{POST_SNAPBACK}>
Photo doesn't include a TDM so doesn't count....
I don't like YZ250's anymore.........check out my avatar, one literally kicked me in the ass
#12 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 11 April 2011 - 03:15 pm
QUOTE(crispy @ Mon 11th Apr 2011, 03:55 PM) <{POST_SNAPBACK}>
sorry, no TDM's present yesterday. I do still have a KTM990 (very impressive style) and an XT660Z on offer tongue.gif
Suzuki SV650S '01
Yamaha TDM900 '04
#13 ChrisG
  • 8,276 posts
Posted 11 April 2011 - 05:43 pm
QUOTE(fruitcake @ Mon 11th Apr 2011, 11:50 AM) <{POST_SNAPBACK}>
+1
Yeah bit I tend to not look that cool when asking bystanders to lift the bike off my leg rotflmmfao.gif
#14 jiff
jiff
  • 688 posts
Posted 11 April 2011 - 05:49 pm
....................that looks helpfull.............but you don't mention, & the pic doesn't show, turning the bars, let alone full lock.....
presumably it doesn't all happen just by means of the 'body lean' alone ?
............(eager student)......Jiff
#15 SelinaXC
SelinaXC
  • 264 posts
Posted 11 April 2011 - 07:39 pm
Tiger 800XC in black & WR400F rider, cohabiting with two TeDiuMs, a Mk1 and a Mk3.
#16 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 11 April 2011 - 07:45 pm
QUOTE(jiff @ Mon 11th Apr 2011, 06:49 PM) <{POST_SNAPBACK}>
first of all: body lean does not steer the bike. This is a very persistent misconception amongst riders. Even after Keith Code' s demonstration on the No BS Bike. Counter-steering is the only thing powerful enough to make a motorcycle seriously deviate from its course.
So then why do racers hang off their bikes and why did I say to push the bike in the corner while keeping your body as upright as possible? That both sounds like steering with body lean doesn't it?
Not quite, both only serve to influence the bike's centre of gravity, albeit with totally different objectives.
Racers try to push the bike as upright as possible ensuring maximal ground clearance while maintaining the same centre of gravity. Using the push technique you try to use the sides of your tyres as much as possible. The sides have a smaller circumference, allowing for shorter turns. Keeping the body upright again ensures the centre of gravity remains the same as when the bike were more upright.
Suzuki SV650S '01
Yamaha TDM900 '04
#17 jiff
jiff
  • 688 posts
Posted 12 April 2011 - 10:17 am
QUOTE
"..................thus ended todays lecture" (duibhce Kaelann)
Oh , not quite my dear!
..........so are you saying that the steering effort is via counter steering, rather than 'direct use of the bars?
.........that is, if I want to U-turn to the right, I push the right-hand bar, not attempting full right-lock by pushing the left?
(whilst keeping my body upright)
.......Jiff
#18 Studley Ramrod
  • 19,217 posts
Posted 12 April 2011 - 11:04 am
QUOTE(jiff @ Sun 10th Apr 2011, 02:58 PM) <{POST_SNAPBACK}>
How did you manage to pass yer bike test ? I never came across a 30ft wide road when I did my U-turn on any of me tests.
Failed my u-turn on me first test sad.gif The road was/still is a tricky fecka tho ! uphill, double camber and very narrow dry.gif
I also fixated on the kerb......yeah,no,yeah,no,yea,nonononooooooo....foot down=fail.
I seem to remember summat about the Aprilia RS250 not being suitable for taking a bike test on as the turning circle was bigger than the Apollo 8 launch pads' !
Oh yeah, if ya wanna reduce the width of the turning circle, do it at a slower speed smile.gif
Edited by Studley Ramrod, 12 April 2011 - 11:06 am.
#19 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 12 April 2011 - 11:46 am
Make no mistake, counter steering is what you do on your bike day in day out. You do it naturally and it is what you have been doing since you first made a turn on a bicycle without the training wheels on. The counter steer input is what initiates your bike to make a turn.
Thé most intense way to experience this effect is to cross your arms: left hand on right grip, right hand on left grip and feel how you make the bike turn. Although I would not recommend this as it is very likely to end up in a full 90 degree lean angle wink.gif
You can also experience it by riding with 1 hand. Find a large abandoned parking lot. Keep the right hand on the throttle, left hand of the handle bars. Start riding in a straight line and push the handlebar forward with your right hand, see where the bike goes.
I once saw a friend riding instructor illustrate this to a pupil by riding pillion, holding the elbows and the pushing on the elbows to steer the bike. I can still hear the girl screaming when he did the emergency swerve manoeuvre. biggrin.gif
Suzuki SV650S '01
Yamaha TDM900 '04
#20 Nog
Nog
  • 514 posts
Posted 12 April 2011 - 11:55 am
Just to be further pedantic wink.gif , counter "steering" has nothing to do with the bike actually turning, its only a means of leaning the bike in preparation for a turn.
Pushing the bars the opposite way causes the bike to lean into the turn due to the gyroscopic nature of the front wheel - even leant over a bike will continue to go in a straight line unless the wheel is then turned the correct way to steer - this is done without even realising usually.
This also only happens at speed, why its being brought up for U turns is beyond me.
