Winter Lay-Up.... .fuel
11 replies to this topic
#1 DaveW
DaveW
  • 59 posts
Posted 17 November 2019 - 09:42 am
I'm not intending to use the bike much for the next three months. I've not used fuel additives previously. Anybody got advice? Thanks.
#2 ramo
ramo
  • 1,177 posts
Posted 17 November 2019 - 10:15 am
Don't need em with todays fuels for that length of time  :good:
#3 Studley Ramrod
  • 19,211 posts
I put some Redex in and it seems to work.  Still got the same fuel in my tank for the past 12 months :blush2:  and it fires up and runs fine.  3 months lay-up shouldn't be a problem imho.
#4 dapleb
  • 18,114 posts
Posted 17 November 2019 - 10:44 am
Agrozzzle not required. This year I am planning on filling with esso superunleaded which they claim contains zero ethanol despite the confusing labelling!! Again unnecessary but I'm doing it anyway. :0)
#5 Wesi
Wesi
  • 2 posts
Posted 17 November 2019 - 08:05 pm
Hi,I always use Seaform which has worked well on my winterised bikes and petrol mower
#6 DaveW
DaveW
  • 59 posts
Posted 18 November 2019 - 12:02 am
Thank you all. Maybe I wont bother if I think I'll use the bike occasionally but if not I'll try the stuff suggested.Great to get feedback from other owners.
#7 madmopedracer
madmopedracer
  • 473 posts
Posted 18 November 2019 - 08:16 am
my 2p worth iv heard that fuels with ethanol in are hygroscopic so will absorb water which can then settle to bottom of the tank causing rusting also a half empty tank can allow condensation to form again falling to bottom of the tank.
so fill to the brim with super whats to lose it just means you have a full tank for when you want to take it for a run
#8 gautrek
gautrek
  • 71 posts
Posted 18 November 2019 - 12:02 pm
Airhead BMW's suffer in this matter. There is a small amount of fuel below the petrol taps so it never gets drained. This tends to be all the crappy stuff so if left it rots the tanks through. So they recommend you totally drain the tank if leaving it. If I am laying a bike up for a few months I use a pump and remove all the fuel.
Edited by gautrek, 18 November 2019 - 12:03 pm.
#9 dandywarhol
Posted 20 November 2019 - 09:52 am
If you've used ethanol E5 or E10 fuel then drain the tank fully, pour into a container with a tap on the bottom and over 24 hours the water will collect in the bottom of the container. Then put the waterless fuel back in the tank and top up with fresh superu sans ethanol.
#10 dapleb
  • 18,114 posts
Posted 20 November 2019 - 12:22 pm
Many super unleadeds now contain ethanol weewan. Also "E5" does not mean 5% ethanol ..... It means "up to 5% ethanol".
So, super unleaded is actually E5 and could contain zero ethanol.... Or 5% .... How helpful!
#11 Snowbird
  • 1,353 posts
Posted 20 November 2019 - 03:04 pm
Avgas contains no ethanol as long as you don't mind a bit of lead, we use 100LL at work. :rolleyes:
#12 dandywarhol
Posted 20 November 2019 - 06:14 pm
Yup - I use 50/50 Avgas, superunleaded (Esso/BP which should be zero eth) in my 51 year old Yamaha 250 racer - burns really well and keeps the piston crowns cool(er)
