Well, Hello!
40 replies to this topic
#1 Navigator1946
Navigator1946
  • 65 posts
Posted 06 June 2020 - 07:15 am
I'm new on here and just popped in to say "hi".
I'm currently a Honda Crosstourer owner but finding the CT a bit too heavy, so I'm looking at an 2008 TDM to run as a second bike with the CT getting sold during the summer. I'm a bit of a Luddite, and like the Yam because it's like the CT in that there's very little gadgetry to worry about. I think we'll get on well together as I age! I'm looking forward to spending time on here to improve my knowledge of my new acquisition.
2008 TDM900 in beautiful black.  Fender extender, after market Bullster touring screen, radiator guard, RM-G crash bars, 12V/USB socket, Oxford heated grips, Bagster tank cover, centre stand, E22 Givi panniers, standard exhausts. Beautiful Acerbis hand guards. <p>2015 Honda Crosstourer Highlander dct. Fabulous bike, but getting heavier as I age. The 9er is its replacement, eventually.
#2 dablik
  • 10,754 posts
Posted 06 June 2020 - 07:40 am
How do and welcome, great choice, you would'nt be the brother of a well known member on here would you !!
#3 Favs
  • 4,395 posts
Greetings
#4 Studley Ramrod
  • 19,214 posts
Posted 06 June 2020 - 07:46 am
Hello and welcome.  Lots to read and see on here.  Post up if you can't find any answers to your questions and some fellow luddites will be sure to answer. :)
#5 drewpy
  • 1,758 posts
Posted 06 June 2020 - 08:50 am
welcome to Carpe.
Loads of info here although threads do go off at a tangent making it hard to navigate, but that'll part of the fun
#6 Snowbird
  • 1,358 posts
Posted 06 June 2020 - 11:39 am
Greetings and welcome, you don't have to be mad to post here but it does help considerably.
#7 Navigator1946
Navigator1946
  • 65 posts
Posted 06 June 2020 - 01:08 pm
Well, thanks, guys.  No, I'm not related to anyone on here, as far as I know, but I did find an entry yesterday about another TDM guy helping his brother who is a CT owner.  I tried making a comment but I think it failed to register for some reason.
As far as I can see, there's little to worry about on the TDM900.  Anyone got any comments on what to look out for on a first viewing?
#8 TKH
Posted 06 June 2020 - 01:46 pm
Welcome!!
Things to look out for are make sure the swinging arm isn't seized, if it's abs, make sure it's working ok - brakes are pretty good especially at the fronts, chain should be set to between 50mm and 60mm which could indicate how well it's been looked after. If has been looked after there's not much to worry about.
How many miles has it done? TDMs are good for round the clock if looked after though.
Everything as you would with another bike, write off (afefcts value) everything is straight, brake calipers clean enough for age, tyres, etc.
#9 leehenty
  • 5,088 posts
Posted 06 June 2020 - 02:42 pm
No he's not, I couldn't convert him.
#10 Studley Ramrod
  • 19,214 posts
Posted 06 June 2020 - 03:22 pm
There's also lots of TDM info on the most excellent JBX site.  https://www.tdm-yamaha.heliohost.org/
#11 chrisr
  • 1,746 posts
Posted 06 June 2020 - 04:37 pm
Hello and welcome, and thank you... makes a change recently for someone to join and introduce themselves rather than just ask for something! I’m sure the TDM will do everything you want it to, you will need to check the rear suspension is greased - plenty on here on the subject. Any problems you only need to ask and someone will help. Don’t forget to show us photos of your new bike!
#12 leehenty
  • 5,088 posts
Posted 06 June 2020 - 04:48 pm
If the bottom bush is seized in, I'm only just recovered from doing Chris R's bike. It was years ago..
#13 Snowbird
  • 1,358 posts
Posted 06 June 2020 - 05:04 pm
I think I may have been guilty of that... :sorry:
Yep just checked my posts, banged to rights! Sorry guys.
OK here goes.... Hello, My name's Dave and I'm a alcaholic TDM850 MK2a owner and a very naughty boy. (there ya go, only 10.5 months late)
#14 dablik
  • 10,754 posts
Posted 06 June 2020 - 05:14 pm
:punishment: :punishment: :punishment:right, punishment doled out  :)
#15 dapleb
  • 18,117 posts
Posted 06 June 2020 - 05:45 pm
Hello dare and welcome.
#16 MickC
MickC
  • 408 posts
Posted 06 June 2020 - 06:21 pm
Welcome to the forum Navs
Edited by MickC, 06 June 2020 - 06:22 pm.
#17 Kelpie
Kelpie
  • 944 posts
Posted 06 June 2020 - 06:39 pm
:welcome:
#18 Snowbird
  • 1,358 posts
Posted 06 June 2020 - 07:23 pm
:punishment: :punishment: right, punishment doled out  :)
I do love a good spanking, ta. :P
#19 James
James
  • 570 posts
Posted 06 June 2020 - 08:18 pm
Welcome to Carpe. I learnt to sail dingy’s on Hornsea mere. Lovely place! I’m sure you’ll enjoy the TDM.
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#20 Bjørge
  • 1,792 posts
Posted 06 June 2020 - 08:23 pm
Welcome! Some of us have even ditched the 900s for the original 850 Mk1 😎
They're that good
