That's an awful lot of work, way above my knowledge, great job indeed, i think your a bit of a wizz bod with Tdm's medmonic
#tdm3Vd900Project
#61
Posted 01 April 2021 - 07:18 pm
#62
Posted 01 April 2021 - 07:35 pm
well i stil have my supertenere 750 , my xt 350 and my nx650 dominator ...........they are waiting for me ..........
#63
Posted 01 April 2021 - 07:49 pm
I'm with dablik, wish I had half the skill you have or even a quarter. Well done there Sir, top job!!
#64
Posted 01 April 2021 - 09:08 pm
Sit further away from the keyboard Dickiebig, it's echoing....
#65
Posted 01 April 2021 - 11:07 pm
here is the run up with cdi stock
here is with the new cdi and tps calibrated and working
Good stuff. I noticed the TPS value moving a round a bit in the bottom left corner.........is that a normal amount of flutter ?
Edited by fixitsan, 02 April 2021 - 10:03 am.
#67
Posted 02 April 2021 - 05:29 pm
i noted the flutation too , does not have any effect in the idle .
#68
Posted 02 April 2021 - 06:28 pm
It shouldn't be a problem because i think it only uses TPS as a load sensor (after reading the manual...!)
#69
Posted 02 April 2021 - 06:52 pm
#70
Posted 19 May 2021 - 07:54 pm
Dear all ,
sorry for the delay , but i have been working far away of home (Spain) so it has been difficult for me to continue updating the project ....
So i had few days off and start to do some work again in the project ..
First this is my actual TDM
IMG_20210216_173406.jpg 168.44KB 2 downloads
IMG_20210216_173458.jpg 326.91KB 0 downloads
and i decided to do this
IMG_20210506_142059.jpg 184.75KB 0 downloads
then decided to install this
IMG_20210506_142137.jpg 175.5KB 0 downloads
then start to install the new wiring for the programable cdi
and off course remove the engine from my red TDM and install on this one .
Everthing went smooth until i removed the engine and looked to the exhaust port ......
IMG_20210510_165756.jpg 209.92KB 0 downloads
as you can see one exhaust port is dark with no signs of oil , the port is dark but dry and the other port is clean ......the exhaust from this port is total withe , even the spark plug ....
Posted 19 May 2021 - 08:34 pm
Welcome back Medmonic, cant believe how many Tdm's you've gotten built so quickly, so whats happened then, blocked oil gallery perhaps ?? sure it will be sorted by the morning
Can i ask where you got your replacement CDI unit from and was it er, very expensive i may/may not need one in the near future if i cant find a refurb one, would'nt need programmable either just bog standard, good to see you posting again
#72
Posted 19 May 2021 - 09:00 pm
Wowza ! Never seen anything like that before Med. Any idea what's caused it to happen ?
#73
Posted 20 May 2021 - 06:53 am
#74
Posted 20 May 2021 - 08:19 am
#75
Posted 20 May 2021 - 02:45 pm
https://www.ignitech.cz/zdroj/en/ceniky/EUR/price%20list%20units%20eur.pdf depending on dhl but looks like between 90 and 133€
Edited by mh1848, 20 May 2021 - 02:51 pm.
#76
Posted 20 May 2021 - 05:54 pm
Hi Dablick , still did not had time to sort out the problem in the engine , i returned to spain to work ..... but iam thinking probly its valve adjustment , that is causing the issue .
regarding the cdi , i got it by themhttps://www.ignitech...t units eur.pdf, with all the cables and posting i paid around 190 euros
Love this, fantastic looking bike. I'm sure, with your skill, you'll soon have it sorted
still not mate , no time during this month .... but iam thinking that may be a problem of valve adjustment ...
probly valve adjustemt in one cylinder , i have to check the valve clearence of both and see if there are differences in the clearence
#77
Posted 20 May 2021 - 06:04 pm
Cheers Muir i know of Ignitech, in fact was you pointed me that way awhile ago, cant make any bloody sense of their website though,
Thanks Medmonic, good luck with the work when you have time.
