The 3VD map might not be any good, you will have to try it first though
The 3VD has a 360 degree crank, but the 900 has a 270 degree crank
If the unit takes a trigger pulse from the flywheel directly it could be possible that it wokrs
I would start with verifying if it works or not, and if it does see how it runs under load.
As long as you don't hear pinking/pre-ignition you can probably safely advance the timing
In the UK we usually get ignition systems set up for a minimum fuel quality of 92RON, but I think the lowest grade we can buy is 95, so you can safely run slightly more timing advanced than standard, maybe by as much as 4 degrees, hence why you can buy a '4 degree advancer' for most bikes.
But if you think you'll go somewhere with 92 grade fuel then tune the ignition for that grade, and then live with the compromise, unless you have 'switchable maps ' ?
