Well, problem is that I don't really remember when the consumtion went up. After or before the rebuild, had the motor in 200 parts and the whole "bike" of the frame. This was last summer.
New pistion rings and valve steam seals = no oil consumtion though. Also I have a third gear again!
The milage is 130 000 km, 80 000ish miles.
I've the FP tubes in it, but they are like 5 years old probably. But they should wear out?
Heavy right hand for sure, but I don't get higher mpg even if I drive as a granny.
Regarding the choke, it might be the case. I changed the plungers a few years ago. But the mechanism isn't running completely smooth. Also if the timing can cause this that might be the case. The chain is really streched out, I'm almost one tooth off. So the timing might actually cause this?
This is my setup now.(Know the starter jet is waaaaay to big, gonna change it back)
The wildcard here is also the fuel height as I had a pain is the a** to get it correct, gave up and ended up riding it instead
Bike is running really well though, just the consumtion that is off. I smell fuel but it doesn't appear on the ground.
Supplier Part Size Comments
NRP carbs Pilot jets 42,5 Pilot screw at 2,5 turns
Wemoto Main Jet 142,5
Wemoto Primary Main Jet(Starter) 142,5
Factor Pro Emulsion tube PN: CRZ-EMU-100120k
Factor Pro Needle 1175-90q-70r-45t_ti Third notch
Biltema Exhaust - Without DB killer
Wemoto Air filter - "OEM"
Biltema Fuel pump 120 l/h, 0,3 bar
Malpassi Fuel regulator 0,1-0,5 bar FPR007, not sure what pressure I'm at -
Fuel height - Not sure, think I was aiming for 8 mm over the line
