Is It A Big Job?
28 replies to this topic
#1 danjohnston89
danjohnston89
  • 63 posts
Posted 03 April 2021 - 08:54 pm
Just wandering how involved/how much of a big job it is to do the valve clearances and the valve guide seal also?
Thanks in advance
#2 Studley Ramrod
  • 19,213 posts
Posted 03 April 2021 - 09:06 pm
According to the Haynes book of mechanical wonderment, its 3 spanners out of 5. :)
Checking/measuring the valve clearances is pretty straightforward, adjusting them is the tricky bit.  It depends on how mechanically minded you are to some extent.  You won't need any special tools and the Haynes manuel gives a pretty good description of how to do it, plus you can allus call in here for any help should you get stuck.
Basically it's plastics, tank, radiator, coolant pipe into cylinder head and thermostat housing off, then you can get at the valve cover.  Valve cover off and plug leads removed and you'll then have access to the camshafts for measuring.
#3 curlylegend
curlylegend
  • 307 posts
Posted 03 April 2021 - 09:44 pm
The valve guide seals would be a head off job though.  If your in deep enough to do the valve clearances you might as well get the head off and regard it as a top end overhaul.
This is not a job I've done myself but you'll get plenty of guidance on here...
#4 Studley Ramrod
  • 19,213 posts
Posted 03 April 2021 - 09:51 pm
oops, forgot to mention the valve seals job.  As Curly says, it's a head off job.  It involves a lot more work and cost than just doing the valve clearances and it would be false economy not to do a head refurb whilst you're at it really.
#5 danjohnston89
danjohnston89
  • 63 posts
Posted 03 April 2021 - 10:02 pm
Thanks very much for the replies.
Valves I would be ok with however not so sure about the valve guides. Ill have a think and also look to get some prices from a garage to carry out the work possibly
Thanks again
#6 ChrisG
  • 8,276 posts
Posted 03 April 2021 - 10:45 pm
You need a valve spring compression tool but doing the guides isn't really that complicated a job.   I spent a fair while with a toothbrush and a can of Mr muscle cleaning up the had when I did it, which was the hardest bit.
#7 drewpy
  • 1,758 posts
Posted 04 April 2021 - 03:59 pm
when i took my valves off i had to modify the compressor as the inlet valves are tiny.
easy enough to do and i replaced the cam chain at the same time.
Cost me £600 as I got the pistons coated as they were borderline worn.
burns no oil now and motors along
#8 Catteeclan
  • 2,440 posts
Posted 04 April 2021 - 07:23 pm
If you're clever you can fire compress air down the spark plugs holes to hold the valves up while releasing the collects for the springs with a forked lever.
Done it on cars but never on a bike, yet.
#9 Snowbird
  • 1,354 posts
Posted 04 April 2021 - 07:30 pm
Or the indian rope trick, feed soft rope down the plughole and turn the engine over so the piston holds the valves shut, make sure you leave some rope poking out or you'll have to remove the head anyway to get it out.
#10 Medmonic
Medmonic
  • 81 posts
Posted 05 April 2021 - 08:33 am
better job to do is always remove the head , give a nice clean , remove all dirty inside of exhaust ports , griding the valve seats for a better sealing , put new seals and adjust the valve clearence in the end .
#11 danjohnston89
danjohnston89
  • 63 posts
Posted 06 April 2021 - 09:30 am
Thanks all. Can the head come off with the engine in the frame?
Im debating weather to do the job myself or not...Im ok at basic stuff but taking the head off etc is something Ive never done. Can you anybody recommend anybody/any garages who may be able to help out? Im based in Salford but dont mind travelling a bit
Thanks all
#12 Medmonic
Medmonic
  • 81 posts
Posted 06 April 2021 - 09:52 am
yes you can remove the head with the engine in the frame
#13 Studley Ramrod
  • 19,213 posts
Posted 06 April 2021 - 01:09 pm
Thanks all
Can I ask, why do you want to do the valve seals Dan ?  Also, what's the mileage ?
A garage won't be cheap and they may also recommend a top end refurb whilst you're having the seals done.  Prolly looking at £600-£800 for a garage to refurb the head, might even be more. £50 per hour labour plus parts at around £200-£300 (New head gasket, base gasket, piston rings and a cylinder hone) depending on if they re-use the rocker cover gasket, coolant and oil etc.  Also assuming the pistons, gudgeon pins and valves are all good too.
#14 danjohnston89
danjohnston89
  • 63 posts
Posted 06 April 2021 - 01:39 pm
I was pointed in the direction of Valve guide seals as there is lots of blue smoke when i fire the bike up initially. Like you say Studley, after speaking with a mechanic this morning he also suggested a top end refurb would be the way to go whilst carrying out the work. He also suggested that it may not be as straight forward as just changing the valve seals and the problem will be fixed but thats something that obviously wont be found out until work on the bike has commenced. He did mention a very rough figure of around £600ish but obviously he wont know the extent of the work until he has investigated. With that in mind, I dont have that amount of money to throw at the bike so Im leaning towards having a go at myself
#15 dapleb
  • 18,114 posts
Posted 06 April 2021 - 01:57 pm
If you(or someone else) does take the heed off I would recommend OEM base and head gaskets. Painful cost but less painful than doing it twice.
Whereabouts are you to?
#16 danjohnston89
danjohnston89
  • 63 posts
Posted 06 April 2021 - 02:09 pm
I forgot to mention the mileage is nearly 39k.
Thanks for the recommendation Monkey Boy, I’m in Salford.
#17 dablik
  • 10,747 posts
Posted 06 April 2021 - 04:02 pm
It's a lot of work Dan but doable, i have done mine but had the benefit of engine out and in the house for a complete rebuild, if you have a Haynes and use this site you'll get it done, not a job to be doing outside though, i would agree with above re oem gaskets..
#18 drewpy
  • 1,758 posts
Posted 06 April 2021 - 04:11 pm
I'm in Monton, so if you want any help and I'm free, PM me
I took the engine out, it was easier that way
Edited by drewpy, 06 April 2021 - 04:12 pm.
#19 dablik
  • 10,747 posts
Posted 06 April 2021 - 04:13 pm
Good man drew, no stranger to the job either  :good:
#20 danjohnston89
danjohnston89
  • 63 posts
Posted 06 April 2021 - 08:17 pm
Thanks all, Drewpy I really appreciate that, I may well be in touch. Thanks again everybody
