Upgraded To A 3Vd Mki
76 replies to this topic
#41 MipeTDM
MipeTDM
  • 92 posts
Posted 31 July 2019 - 03:55 pm
Btw the link to the carb diaphragms are for the mk2 ones. Not sure if a mk1 has the same size.
#42 MipeTDM
MipeTDM
  • 92 posts
Posted 31 July 2019 - 04:38 pm
Double
Edited by MipeTDM, 31 July 2019 - 04:38 pm.
#43 Studley Ramrod
  • 19,202 posts
Posted 31 July 2019 - 06:16 pm
Pretty straightforward Wicky and it's all in the Heinz Manuel page 4.10
#44 MickC
MickC
  • 404 posts
Posted 31 July 2019 - 06:54 pm
Wicky
MK2a carbs straight on at least need 2A carb to airbox rubbers as 2A carb inlet mouths about 10mm wider than MK1 or MK2,I just got a complete airbox rubbers and filter for a 2A and I had no carb/running issues at all,when I did put some MK1 carbs on to see if i could feel the differance I would say 2A carbs were smoother and returned 58ish to the gallon Mk1 more like 54 not a big deal,but 2A carbs back on.
#45 wicklamulla
Posted 01 August 2019 - 12:18 am
great info folks tanks very much. Well soaking the carbs in the vinegar for 1.5 days has cleaned them up a bit externally but they need ultrasonic cleaning as the internals are shocking!  A chap was saying on Facefook that he bought a cheap used foot spa in a charity shop and used it with a cleaning solution to clean his carbs on the cheap!  Local boike shop want £80 to ultrasonic clean the carbs.
#46 Studley Ramrod
  • 19,202 posts
Posted 01 August 2019 - 08:32 am
Might cost a lot less than £80 if you strip the carbs first ?  A few years ago I looked around for a sonic bath that was big enough to take a pair of carbs and it wudda cost me the best part of £200 for an industrial type machine.
#47 MipeTDM
MipeTDM
  • 92 posts
Posted 01 August 2019 - 11:10 am
Why not poke around and scrub the carb internals first? Ultrasonic is generally overrated IMO :P (hence the prices)
#48 wicklamulla
Posted 03 August 2019 - 08:42 am
Ok I tried the soak them in vinegar ferra few days, it helped a little but they need cleaning properly. When I undid the float bowls this piece fell out. Is it replaceable?
#49 MipeTDM
MipeTDM
  • 92 posts
Posted 03 August 2019 - 10:09 am
Yes, it's number 18 here:
https://images.cmsnl...975374_b5e4.gif
Available on that site, but I also see one on ebay from UK, searching for the part number 1HX1456500
#50 wicklamulla
Posted 03 August 2019 - 10:25 am
Mipe TDM  i love you.
#51 MipeTDM
MipeTDM
  • 92 posts
Posted 03 August 2019 - 10:59 am
:blush2: glad it helps!
#52 Studley Ramrod
  • 19,202 posts
Posted 03 August 2019 - 12:26 pm
Looks like it has been overtightened in the past and snapped off. You'll prolly need to remove the bolt thread that's still stuck in the emulsion toob afore you can fit a new bolt. Not a problem if you're fitting new toobs though. :)
The brass sleeve should lift off so best remove it afore it goes missing.
#53 MipeTDM
MipeTDM
  • 92 posts
Posted 04 August 2019 - 06:59 pm
I've had good success removing corrided carb parts using boiling water. Just pour it over the area of the stuck part, like this broken bolt. It breaks up the corrosion due ti the different materials exoanding slightly different.
Probably best to remove plastic parts still, but the 100 degrees limits the temperature so nothing really gets fried.
Btw some of the air jets I just left in place because they were so corroded I had 0 confidence in removing them in 1 piece.
Cleaned them and the passages of course.
Edited by MipeTDM, 04 August 2019 - 07:03 pm.
#54 wicklamulla
Posted 05 August 2019 - 09:58 pm
tank yew,  the boiling water did the trick.  carbs are at the local boike shoppe now for ultra sonic cleaning,  by the time they are done the LiteTek carb kits shud have turned up from Toyland.
#55 dablik
  • 10,735 posts
Posted 06 August 2019 - 09:40 am
You doin the butterfly shaft an all wicki with new seals or not bothering..
#56 wicklamulla
Posted 06 August 2019 - 11:19 am
errrr    ummmmm  ahhh oil see when the bits arrive as to how confident i feel!  if i struggle oil send them to Allens Carbs. as they will be well versed in the process.  They just sold me 2 of those soft brass bolts that live undeer the carb. float bowl for £11 including p&p. (1HX145650000) apparently they break for a pastime.
#57 dandywarhol
Posted 19 August 2019 - 12:12 pm
Cillit Bang is also a great carb cleaner, inside and out
#58 Studley Ramrod
  • 19,202 posts
Posted 27 November 2022 - 07:21 pm
Just resurrecting this topic as I'm now the owner of the aforementioned mk1 :)
#59 alunl
alunl
  • 356 posts
Posted 27 November 2022 - 07:28 pm
Look forward to meeting up with you in the summer Studders, you on day and me on No7.
The fundamental cause of trouble in the world today is that the stupid are cocksure while the intelligent are full of doubt.
~ Bertrand Russell 1950
#60 dablik
  • 10,735 posts
Posted 28 November 2022 - 11:40 am
Just think Studs, you'll have all the time in the world to fix the gear box now on the auld one  :D
