Fork Seals Going ?
25 replies to this topic
#1 Studley Ramrod
  • 19,214 posts
Posted 15 May 2019 - 06:35 pm
Bike's been stood for 6 months and I've noticed today a smear of fork oil on both forks. Nothing more than the slightest residue really. Seems really odd that both forks are the same and I'm wondering if the seals might have dried slightly ?
Also, anyone know if it'd be an MOT fail, there's no real amount of oil there, just a light residue.
#2 James
James
  • 570 posts
Posted 15 May 2019 - 06:43 pm
Depends on how fastidious your tester is Studders, but leaky seals are a fail.
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#3 dapleb
  • 18,118 posts
Posted 15 May 2019 - 06:59 pm
Prolly just from standing. Some peeps have had good luck with running a little tool round the seal... Or improvised with a milk bottle. That might learn em.
#4 dapleb
  • 18,118 posts
Posted 15 May 2019 - 07:31 pm
Never used em as me old knackered forks are STILL going without leaks.... But summat loike this SR
https://www.ebay.co....mlHZ3kJIZW7BozA
Pop or milk cartoon will print do same thing.
#5 Studley Ramrod
  • 19,214 posts
Posted 16 May 2019 - 08:36 am
I saw the video of some guy using one of them on his totally knackered Harley, didn't work at all, but wasn't really meant to as the forks had no seals in 'em. :lol:
Think you might be right with it just standing, I'll keep an eye on 'em.
#6 wicklamulla
Posted 16 May 2019 - 08:44 am
me tinks if ya cud take her somewhere to a private closed road and ride it around some it may re-invigorate the seals with some movement and they may reseal.  good shout regarding the plastic milk carton.
#7 Studley Ramrod
  • 19,214 posts
Posted 16 May 2019 - 03:12 pm
I've been pumping the front end a few times over the past 24hrs and the residue seems to be almost gone now. :)  A proper ride would help though.  Might chance my arm and see if it'll pass the mot.
#8 wicklamulla
Posted 16 May 2019 - 03:28 pm
whas the deal if yer boike has a loight fork oil mist visible but only you know about it as there are fork gaiters covering it up,  are the MOT tester meant to lift the gaiters and check the forks fer leakage?
#9 Rallyist
  • 3,253 posts
Posted 16 May 2019 - 04:21 pm
Tester not allowed to lift gaiters if secured total no no.
#10 dapleb
  • 18,118 posts
Posted 16 May 2019 - 04:22 pm
Forks or fork yoke:
fractured, insecure, excessively deformed or excessively corroded
Major
in such a condition that steering control is adversely affected
Dangerous
Forks or fork yoke with an unsafe modification
Major
No I don't think they would be expected to remove gaiters in the same way not expected to remove engine trays/covers.
They can cover themselves by stating item not visible.
Either way I reckon SR will be fine for MOT test regarding forks.
#11 PICARD
  • 1,744 posts
Posted 16 May 2019 - 05:41 pm
Forks or fork yoke:
Major
Dangerous
Major
S'right....my tester says they can't move gaitors to inspect forks. S'prise to me but hey.
#12 Andy25
Andy25
  • 335 posts
Posted 16 May 2019 - 07:37 pm
A small amount of Kitchen roll under dust seal has been known
to get a dodgy seal through an MOT
#13 Studley Ramrod
  • 19,214 posts
Posted 23 August 2019 - 12:39 pm
Good news. :)  My leaky fork seals are no more.  I was convinced that they were going to get worse.
Pic of leaky seal.
Attached File  leakyforkseal.jpg   227.43KB   0 downloads
However, I thought I'd try again at pumping the forks (3rd attempt) to see if the seals bedded in and noticed one of the seals stopped leaking, and the 2nd wan wasn't leaking as much. I didn't have an mot so couldn't ride the bike but took a chance and booked in for an mot yesterday.  By the time I'd ridden the bike a few miles to mot centre, taking the long way round, the seals had completely dried up. :)  I now have an mot with no advisories.
Sooooo, the leaky seals musta been caused by the bike being stood since October last.
#14 dapleb
  • 18,118 posts
Posted 23 August 2019 - 12:44 pm
Free fix.... Don't happen often that. Well done SR.
#15 Studley Ramrod
  • 19,214 posts
Posted 23 August 2019 - 12:46 pm
Just thought it odd that both seals leaked at the same time esp. as I hadn't pulled any wheelies lately. :D
#16 KAL850
KAL850
  • 7 posts
Posted 03 February 2020 - 04:03 pm
Wish mine was a free fix. They were ok when I bought it 2 weeks ago... I've just hot it back from carb and shim work, done 400 miles o it and forks are leaking like a sieve.
Somehow dont think jumping up and down on them a few times is going to sort it... they've had better than that on the roads. More expense already... my tdm is getting tds
#17 dablik
  • 10,757 posts
Posted 03 February 2020 - 05:05 pm
Just double up on the weetabix before you pull the forks apart, put some monkey piss around the seals awhile before you start and use a heat gun gently, you'll find both bushes on Wemoto but oem seals generally recommended....
#18 dandywarhol
Posted 05 February 2020 - 12:43 pm
Seal weeping often happens when laid up - the plastic took does work for me but only after you thoroughly clean around the seal before inserting yer tool (f'nar, f'nar), having first lifted the dust cover up.
When finished, apply grease under the dust cover to stop stiction on the dust cover and block any future fluid seepage - job's a carrotee
#19 Quadsey
Quadsey
  • 52 posts
Posted 21 May 2020 - 05:01 pm
Think I may have availed of this free fix. Bike hasn't been out much due to lock down. Went for a spin yesterday and this morning i noticed some oil on the right fork. After reading a potential fix on here i went out and wiped it clean, rocked the forks up and down, a little oil made its way out again. Cleaned that off and on the second and third pumping of the forks, nothing! I'll check it again in the morning but its either been a free fix thanks to the collective knowledge on here or the forks have no oil in them  :lol:
"Touch not, less ye be touched" -Brodie 1995
#20 butcher650
butcher650
  • 614 posts
Posted 21 May 2020 - 06:37 pm
Mines been sitting nearly three years, and I too have this misting, but also dribbles down the fork leg. I've wiped it a couple times, and I haven't even pumped the forks. Checked again today after a couple days, and it's dribbling down the fork leg again, so I think I'm just going to do them. Will be worth it as its had loads of other stuff done too.
