'96 850 17" Tyre Size
32 replies to this topic
#1 drewpy
  • 1,758 posts
Posted 04 February 2018 - 05:42 pm
Hi Folks,
tried searching and can't seem to find the answer.
what size tyre should I use for my 17" front wheel?  this is for 1996 850
the standard thunder race fitment is 120/70 and standard 18" size is 110/80
thank you
Drewps
#2 Favs
  • 4,395 posts
Posted 04 February 2018 - 08:06 pm
My Saturno runs 110/70 front and 140/70 rear standard - I have 120/70 & 160/60 instead and they work great for me
#3 drewpy
  • 1,758 posts
Posted 04 February 2018 - 08:56 pm
thanks, very helpful.
anyone have info regarding TDM's?
#4 Favs
  • 4,395 posts
Posted 04 February 2018 - 10:36 pm
I thought your q was about compatible tyre sizes/profiles which handle well - my mistake
#5 Apache
Apache
  • 553 posts
Posted 05 February 2018 - 10:33 am
Your info was valid. It's about wheels and tyre profile. What difference does it make which cycle they're on ?
#6 drewpy
  • 1,758 posts
Posted 05 February 2018 - 12:21 pm
Thanks for the info, it might handle well on the Saturno, just need to see if it's any different for a TDM?
there may be different steering angles, weight etc etc. that might make a difference
\just seen on faceache that someone has the 120/70 so spot on Favs :badgerrock:
Edited by drewpy, 05 February 2018 - 02:54 pm.
#7 drewpy
  • 1,758 posts
Posted 12 March 2018 - 07:06 pm
finished paint the front 17" weekend.
what do you think?
#8 Favs
  • 4,395 posts
Posted 12 March 2018 - 07:11 pm
Very nice. :good:
#9 Bjørge
  • 1,792 posts
Posted 13 March 2018 - 07:26 am
Is that a Thunderace wheel ? A direct replacement ?
Doe you need to lower the fender for looks ?
#10 drewpy
  • 1,758 posts
Posted 13 March 2018 - 12:50 pm
FJ1200 wheel, front guard will need lowering.
is a direct replacement but someone mentioned that the spacer needs trimming or buy an xs400 spacer so I have that just in case.
#11 Bjørge
  • 1,792 posts
Posted 13 March 2018 - 04:50 pm
Thanks ! Will try this year, I guess  :)
#12 drewpy
  • 1,758 posts
Posted 13 March 2018 - 08:48 pm
I'll let you know how I get on, fitting the new R5 tyres on, sucessor to PR4
#13 drewpy
  • 1,758 posts
Posted 29 March 2018 - 03:00 pm
well I've finally got the 17" wheel fitted to the TDM.
I had to have another spacer made as the original one was 2mm too small and would have put a side load on the bearing. I also had to purchase a C3 bearing as that was the only size there was that would fit the 17mm axle and the wheel.
Last thing I had to do was put a small washer twixt speedo mech and bearing as the disk alignment was out (talking 1 mm here, and made a big diference)
Got the R5 fitted and took the girl out for a ride, wow much better with handling and feels so different to the 18".
had to lower the front guard too so use 45mm x m6 stainless screws and about 25mm tubing to lower.
Now there's room for a fork brace :pimp:
Edited by drewpy, 29 March 2018 - 03:00 pm.
#14 dablik
  • 10,754 posts
Posted 29 March 2018 - 03:34 pm
Nice, mk2 is already a sweety around the bends, that's gonna be on rails now drewpy :good:
#15 drewpy
  • 1,758 posts
Posted 29 March 2018 - 03:47 pm
hopefully, just got the paint the rear wheel and get the rear R5 fitted. tyre guy recommended 36psi front and 42psi rear
#16 dablik
  • 10,754 posts
Posted 29 March 2018 - 03:55 pm
Hm, found 36 on a 17" front on the 9r too much, affected braking to a degree, i found 33psi the sweet spot, worth starting off at 36 anyway, and being a fat pud 42 on the rear is normal for me..
#17 drewpy
  • 1,758 posts
Posted 19 May 2018 - 03:49 pm
done 50% of the rear wheel now, not perfect but good for this bike
when I've done the other side, I'll be painting and laquering again. prob double laquer the paint to shrug off the crud
#18 dablik
  • 10,754 posts
Posted 19 May 2018 - 07:01 pm
:cool: what's the grey paint you used drew ! and did you clearcoat on the front, i have a grey can of el grigio which was made up for a past member (Rip Charlie) which is at an end at your grey looks quite similar on the photo..
Nice job btw, that's blingin :cool: :cool:
#19 Studley Ramrod
  • 19,214 posts
Posted 19 May 2018 - 08:07 pm
Good job Drewpster. :good:
#20 Favs
  • 4,395 posts
Posted 20 May 2018 - 09:34 am
Liking those rims :good: . Future RSI claim?
