That and the fact its going from 8 injectors to 2.
Should be ok because all its doing is modifying a signal thats already there, by a percentage. It's doesnt care at all about timing. The crank position feed is solely for rpm I believe
I picked up on the 8 injectors you mention earlier but didn't comment. A sophisticated machine that Suzuki ! (that particular bit of it anyway !)
You're probably right that it will work from the ECU derived injector signals, because in some bikes, such as the TDM, the injectors open before the inlet valves open, at high revs (according to when I put an oscilloscope on mine anyway) and then fire quite late at lower revs with low load......I think there was at least a 25 degree difference in timing between the extremes of RPM
