900 Abs Caliper Kit
4 replies to this topic
#1 catsbum
Posted 16 September 2021 - 05:40 pm
So if you remember I blew a rear brake hose on my way to Orkney in June.
Took ages for the replacement to arrive. Today the abs brake man came to fit it. He knew what he was doing but found the seals weeping slightly.
So! is there a difference between the 900 caliper rebuild kit and the 900 abs. For me I can't see any difference.
Cats
Edited by catsbum, 16 September 2021 - 05:52 pm.
#2 Catteeclan
  • 2,440 posts
Posted 16 September 2021 - 05:47 pm
Seals on the piston or the seals on the banjo bolt?
Would expect them to be the same but need to check.
Edit, Flowers list the caliper assembly different, it comes with the carrier too.
But the piston and seal kit is the same between a 2004 non and 2006 with abs.
Edited by Catteeclan, 16 September 2021 - 05:56 pm.
#3 catsbum
Posted 16 September 2021 - 05:53 pm
Sorry Cattee
Piston
#4 catsbum
Posted 16 September 2021 - 06:20 pm
Mine 2007
#5 Catteeclan
  • 2,440 posts
Posted 17 September 2021 - 05:27 am
Seal kit and piston the same part No on the 2007 too.
I wouldn't mine a bet that the caliper is the same through the range with the difference in the carrier for the ABS sensor. Your money though.
