Losing My Bearings
10 replies to this topic
#1 Dazmk2850
Dazmk2850
  • 13 posts
Posted 28 May 2020 - 05:35 pm
Hi everyone
I have a mk2 tdm without the fuel gauge from year 98.
My sprocket carrier bearing went and minced my rear wheel.
I am purchasing a set of new wheels tomorrow but when i look for bearing kits I keep seeing 4 listed.
Is this correct?
Does the tdm have 4 bearings in the rear wheel setup?
Im sure it was 3 and the book my mate has says 3 so im unsure now.
Any light on the matter would be fantastic 💡👍
#2 Bjørge
  • 1,792 posts
Posted 28 May 2020 - 06:17 pm
As I recall, 3 in the wheel and one in the sprocket carrier
#3 dablik
  • 10,754 posts
Posted 28 May 2020 - 06:59 pm
Correct, you need four bearings one for the sprocket carrier..
#4 dapleb
  • 18,117 posts
Posted 28 May 2020 - 07:46 pm
Are you sure it's not a 9'er?
#5 Favs
  • 4,395 posts
Posted 28 May 2020 - 09:10 pm
Tee hee him
#6 wicklamulla
Posted 28 May 2020 - 09:27 pm
:clapping:  ;)  :rotflmmfao:  :lol:
#7 Dazmk2850
Dazmk2850
  • 13 posts
Posted 28 May 2020 - 09:40 pm
Is the 9 known for doing this?
I wouldn't have noticed if i didn't hear the sprocket nuts catching on the swing arm.
A week ago the wheel was fine no play at all but it obviously wasnt fine underneath 😭
#8 dablik
  • 10,754 posts
Posted 29 May 2020 - 06:34 am
Not happened to the 9r far as i'm aware, the referance was to "mincing" cos 9r riders is efeminate, i'm okay now as back to a mk1 :)
Check the bearing area inside the sprocket carrier it may have worn some over time, if it's bad replace otherwise use some loctite on the new bearing, it's happened a few times, mainly due to age me thinks.
#9 Rallyist
  • 3,253 posts
Posted 29 May 2020 - 07:51 am
Remember in the sprocket carrier there is a reduction collar in the bearing that appears in some cases to be part of the bearing it's not so be careful  :good:  :good:
#10 wicklamulla
Posted 29 May 2020 - 09:53 am
yes it does happen to TDM900's most loikely jew to pressure washing / steam cleaning
bleddy good tip there Rally as that fooled me once afore.
#11 dandywarhol
Posted 31 May 2020 - 08:28 pm
https://www.fowlersp...70-b/rear-wheel
