And today i received my head gasket for the 900e cylinder block ...yupieee time to work
IMG_20201208_145551.jpg 95.65KB 0 downloads
Posted 08 December 2020 - 09:12 pm
Posted 08 December 2020 - 09:23 pm
So Head in Place , time to torque and make the correct timing of the engine
IMG_20201208_145810.jpg 145.14KB 0 downloads
IMG_20201208_153256.jpg 126.7KB 0 downloads
Posted 09 December 2020 - 12:12 am
welcome back, we were wondering where you had gone. Please keep sharing your knowledge with us even after Brexit!
Posted 09 December 2020 - 06:47 pm
Have you checked the piston deck height compared to the 850? from memory Emmett had to have his pistons machined to get the compression ratio correct. I would grease the piston tops, lightly tighten down the head and carry a combustion chamber volume test by adding paraffin down the sparkplug hole at TDC until it comes halfway up the plughole. Use this formula to calculate the compression ratio:
Cylinder volume (CC) + combustion chamber volume and divide that figure by the combustion chamber volume. You should be aiming for around 11:1.
Then remove the head, put modelling clay into the valve pockets in the pistons, refit the head, time the cams and slowly turn the engine over to see the imprint of the valves in the pistons, remove the head again, remove the clay, cut in half and measure the clearance - OR risk terminal engine damage.
Edited by dandywarhol, 09 December 2020 - 06:56 pm.
Posted 09 December 2020 - 07:54 pm
That's exactly what I was about to say..........honest.
Good work Medmonic. Did you replace the valve stem seals ?
Posted 11 December 2020 - 07:06 pm
I did check the piston deck height against the 850 and they were the same , and iam using a 850 head , the valves dont touch the piston deck regarding the compression ratio it will increase a litle bit due to larger pistons , but dont know how much ....... well if does not work i have to do as you said , will be more correct !! But thaks a lot by the advise , it will help me in the next engine
yep all valves with new steam seals from Athena brand
Posted 11 December 2020 - 07:48 pm
IMG_20201208_161507.jpg 231.68KB 0 downloads
IMG_20201208_170530.jpg 225.19KB 0 downloads
IMG_20201208_185812.jpg 240.95KB 0 downloads
Edited by Medmonic, 11 December 2020 - 07:50 pm.
Posted 11 December 2020 - 08:39 pm
Progress is looking good there Med, be good to hear how it goes afterwards.
Posted 12 December 2020 - 11:37 am
Nice work!
You should find the combustion chamber and gasket volume to be 44.65cc which gives a 10:1 ratio for the 850 engine.
The additional bore size from 89.5 to 92, assuming the same head/gasket will give 11:1. Spot on. All you need now is a pair of Kent Yam09 cams
Posted 12 December 2020 - 07:07 pm
Nice work!
dont make me dream
already preparing the bike whi will receive the engine , lot of work coming specially on the wiring , iam installing some extra sensors to monitor the engine
Posted 12 December 2020 - 09:20 pm
dont make me dream
Sorry, typo - the 850 should have read 10.5:1 stock
Posted 08 January 2021 - 11:41 pm
i always get an involuntary shudder when i think about having to rebuild engines. My philosophy has always been, 'if it needs more power, fit a bigger engine!'
fair play to you you are doing a top job
Posted 30 January 2021 - 08:43 pm
hello again ,
i have being away in work , so not much updates ...
just restarted the project 2 days ago ..
basically the engine is installed on my red tdm , the engine removed will be installed on my black tdm , since her engine had oil mixte in the water .
so basically iam installing two engine at same time
IMG_20210128_144238.jpg 260.89KB 0 downloads
this is the 850 3vd engine with 4tx gearbox installed that goes now to the black tdm
Posted 30 January 2021 - 08:49 pm
IMG_20210128_144257.jpg 175.82KB 0 downloads
the 3vd900 engine already in position
IMG_20210129_151558.jpg 203.41KB 0 downloads
my black tdm waiting for her new engine
thanks man
Posted 11 March 2021 - 08:26 pm
Well, the project have some updates , finally the engine is running , but with small changes in the engine .
First i had to remove the carter that was from tdm 900 and it was deeper than the original tdm 850 , the reason was that the exhaust was touching in the carter , no clearence at all .
then the upper case carter had to be replaced , was leaking oil due a small diference in shape , so removed the 900 top case carter and install the 850 original .
the engine is running fine , but now i have to instal new cluster and wiring to run 3 sensors ,
- engine oil pressure
- engine oil temperature
- engine coolant temperature
But for starting the engine the old setup was fine , just had to make the exhaust and install all in the frame
IMG_20210310_114627.jpg 253.8KB 0 downloads
IMG_20210310_114607.jpg 110.86KB 0 downloads
IMG_20210310_114530.jpg 138.73KB 0 downloads
IMG_20210310_114540.jpg 140.18KB 0 downloads
IMG_20210310_114601.jpg 97.32KB 0 downloads
Posted 12 March 2021 - 01:15 pm
Congratulations Medmonic.
Posted 12 March 2021 - 05:28 pm
Posted 12 March 2021 - 06:04 pm
Good work that man, I bet that was satisfying to hear it crackle into life.
Posted 12 March 2021 - 06:36 pm
Good job medmonic
Posted 13 March 2021 - 12:36 pm
