http://www.carpe-tdm...l=&fromsearch=1
Rear are diff Fj vs 9er. Wee man had this prob in banska biscuit tray when we were touring.
Forgot about that!
Posted 28 January 2021 - 12:31 pm
Forgot about that!
Posted 30 January 2021 - 08:44 pm
Okay, problem solved.
Wemoto (who supplied the pads) were really helpful, and measured other pads they had in stock, which turned out to be the same as the EBC's, so had to assume problem lay elsewhere.
Decided to pull it apart again to investigate. Brakes are not something I'm prepared to take any chances with, I knew something wasn't right and was determined to get to the bottom of it. Not being confident of getting the seals out without damage, ordered another set.
Getting it apart, it was apparent that something wasn't right at all. The pistons had gone tight, didn't want to go further into the callipers, and were buggers to get out. Took the seals out, cleaned everything and polished the pistons again. Maybe my imagination but the new seals (from a different supplier) seemed ever so slightly looser, on a trial fit over the pistons, than the last set.
Got it bled, with the EBC pads fitted, up on the stand, spin the wheel - nice and free. Pads grab nicely and obviously are coming back off the disc, as the wheel now spins as I expect it to. Will give them another bleed once bedded in a bit, just for piece of mind.
Perhaps all aftermarket parts aren't equal.
Thanks for your input chaps.
Posted 30 January 2021 - 08:46 pm
Posted 30 January 2021 - 09:09 pm
Good job Sphere, guess i've been lucky with aftermarket seals in the past..
Posted 30 January 2021 - 09:44 pm
Edited by Apache, 30 January 2021 - 09:44 pm.
Posted 30 January 2021 - 10:00 pm
I know bugger all about niners but if yourself or somebody here has a factory manual it should list pad start thickness in the maintenance specifications section.......my 4TX manual has that information ( 5.5 mm pads all round on a 4TX )
I'd be surprised if the 900 manual omits the information you're after....hth
Good thinking, sir. I had not realised the specs. included that.
My 900 WSM says lining thickness 5.5mm front, 5.8mm rear.
Shame then that all the aftermarket folk quote the total thickness including the backing plate!
Posted 30 January 2021 - 10:02 pm
