is it normal for the header pipes to be "offset" or are these pipes bent/badly made.
I have put a ruler on the end of the pipes so you can see what I mean
thx for help
Posted 12 February 2021 - 02:56 pm
thx for help
Posted 12 February 2021 - 07:30 pm
Look a bit bent to me, trouble fitting them back on !!
Posted 12 February 2021 - 09:01 pm
Posted 12 February 2021 - 09:06 pm
Well here's a few pic's of some I took a few weeks ago,
I know the tape is misleading, but they looked level, no wobbles when I took the first picture
Posted 13 February 2021 - 10:51 am
thx for your replies, they are pipes I just bought on ebay,
the seller responded
"They're perfectly fine you'll always get a bit of flexibility in the headers.
Is that fair comment or is the gap to big to bolt up (bearing in mind the torque setting on the bolts), the pipes are quite strong I cant bend them with my hands
Posted 13 February 2021 - 11:09 am
Posted 14 February 2021 - 09:39 am
If they were made of scaffold poles you'd have something to worry about but they'll seal up fine with some new gaskets.
Posted 14 February 2021 - 01:00 pm
Does anyone know what these bolts are for (at the bottom of the downpipes)
Posted 14 February 2021 - 01:38 pm
Posted 14 February 2021 - 01:47 pm
Apart from reading exhaust content prior to the silencer I've no idea but they're nothing new. My 78 Kawasaki has one in all four pipes.....I'd be interested to know if anybody can enlighten....
Almost certainly exactly what they're for
Maybe they've been on a bike with an aftermarket ECU which needs two lambda/oxygen sensors, or perhaps someone wanted to adjust the CO setting of each cylinder until they found the perfect balance.
Maybe they're for giving access to the inside of the pipe, to knock out any dents !
Posted 14 February 2021 - 02:02 pm
"Maybe they're for giving access to the inside of the pipe, to knock out any dents !"
yes the seller did not mention the mis-aligned headers or the massive dent
thats ebay for you
Posted 14 February 2021 - 02:17 pm
Posted 14 February 2021 - 10:52 pm
Posted 14 February 2021 - 11:45 pm
Early TDM'S had exhaust gas sample ports to set up the co settings before the cat, mine has them never seen them after about 2006 bikes
Was there a change prior to that too do you know ?. Mine definitely does not have them, a 2002 model on an '04 plate
Posted 16 February 2021 - 04:36 pm
Posted 16 February 2021 - 05:59 pm
Posted 16 February 2021 - 06:28 pm
Gas injection ?
https://www.youtube....h?v=XDfmXrVFx-0
Edited by fixitsan, 16 February 2021 - 06:29 pm.
Posted 16 February 2021 - 08:16 pm
Posted 17 February 2021 - 06:29 pm
Edited by Gdogg, 18 February 2021 - 05:20 pm.
Posted 18 February 2021 - 03:37 pm
[quote name="thong" post="385778" timestamp="1613311342"]"Maybe they're for giving access to the inside of the pipe, to knock out any dents
thats eBay for you !!
As far as Im concerned if the seller did not mention that bloody great dent & the fact that the headers are mis-aligned in the eBay ad they would have been boxed up and on there want back the the muppet who dumped them on me even if they were super cheap!! Just saying.
yes I have returned them
