Posted 13 March 2021 - 07:21 pm
Take lever out, bore out the eye the minimum amount to round, press in a brass bush with top hat washer made to fit bore and height of gap. Make sure the washer bit is at bottom.
I had to do this to the Royal Enfield levers from new, as they flapped up and down like castanettes at idle, driving me nuts. No flapping now. You will need to find a model makeror someone with access to a metal lathe.
