Timing Advance
25 replies to this topic
#21 wicklamulla
Posted 05 August 2018 - 11:03 am
Yes i did..
I tried uploading pics from my phone, but it didnt work, i will post some
Pics from my computer, when i get a spare minute at work
yerra super trooper,  tanks.
#22 chrisbee
chrisbee
  • 392 posts
Posted 06 August 2018 - 06:30 am
Attached File  igadv.JPG   175.09KB   1 downloads
These are all the tools I needed to do this little job
Attached File  igadv2.JPG   121.47KB   1 downloads
Attached File  igadv3.JPG   142.38KB   1 downloads
These little tangs need to be got rid of, I filed them off
Attached File  igadv4.JPG   113.34KB   2 downloads
Attached File  igadv5.JPG   105.84KB   1 downloads
Attached File  igadv6.JPG   94.88KB   1 downloads
If anyone tries this, don't forget to cover up with insulting tape, the pick up is a magnet, and all the filings will stick to it.
#23 fixitsan
  • 4,671 posts
Posted 06 August 2018 - 07:33 am
I spoke with someone else who had done this, and he correctly pointed out that because of the arc radius of the pickup, 1mm of movement is less than 1 degree of advance. Cutting the slot out to get 5mm of movement is worth just over 4 degrees of advance, there isn't very much bracket material to play with but 5mm is just possible
Edited by fixitsan, 06 August 2018 - 07:44 am.
#24 wicklamulla
Posted 06 August 2018 - 09:15 am
Cheers fer the info. bhoys.
#25 paultdm850
paultdm850
  • 114 posts
Posted 05 November 2018 - 08:52 pm
:good:
#26 fixitsan
  • 4,671 posts
Posted 05 November 2018 - 09:06 pm
Since getting my KTM I see that the way KTM deal with this is to provide a male/female plug connector on a wire going into the ignition CDi box. If you run a minimum of 95RON then you leave the connectors mated, but if the fuel is below 95RON you open the connector. This gives a similar +/- 4degrees of ignition change
