Running Lights
20 replies to this topic
#1 Cclivve
Cclivve
  • 27 posts
Posted 19 July 2018 - 04:37 am
To aid visibility during day time it seem prudent to fit some auxiliary LED running lights. I don't do much night riding if at all so it's prime purpose is to be seen on the road. There seem to be plenty of cheap lights from China are they good enough for the intended purpose ? Be interested to know members thoughts and recommendations.
This is the bike.
#2 TDM4ever
TDM4ever
  • 302 posts
Posted 19 July 2018 - 06:52 am
Watching this thread  :)
#3 fixitsan
  • 4,676 posts
Posted 19 July 2018 - 08:44 am
most of them are more than adequate in my experience. Some of them don't have the best waterproofing but that's easily fixed by adding some silicon sealant.
It's a good idea to have them on a switch so you can turn them off or dim them at night if they're very bright
#4 WayneUK
WayneUK
  • 29 posts
Posted 19 July 2018 - 10:10 am
I have a switch on mine but the lights have 3 settings, sometimes when i switch the lights on they are out of sync? ie one flashing other hi beam, is there a way of stopping this?
#5 fixitsan
  • 4,676 posts
Posted 19 July 2018 - 11:40 am
I don't think so. There are some videos on YouTube showing which I you need to short out on one or two types of lamps but there are so many variants. You might be lucky and find one like yours on Google. It's a daft system they employ.
Some lamps with the same programs have 3 wires and you select your preference by touching the third wire to the +very supply wire.
#6 Johnners
Johnners
  • 120 posts
Posted 19 July 2018 - 12:27 pm
The 3 mode lights can be synched by disconnecting one and cycling the other until they match. I had the same problem - no matter how long you leave them off, they remember what the next 'mode' is Hi, Low, Strobe.
#7 Hombre
Hombre
  • 448 posts
Posted 19 July 2018 - 03:35 pm
My 3 setting lights always synch.  The memory is only as long as the capacitor power to the chip.  Both run through one switch taking the power from the back of the dip beam.  Position 1 is day, 2 is night and 3 is rapid flash.  If I park-up or stop for fuel the memory is lost and they start on bright.  If you stall or engage the clutch with the side stand down, they will start on the next setting along when you quickly restart.
They are available with only one setting.
#8 PICARD
  • 1,744 posts
Posted 19 July 2018 - 03:52 pm
Safego from amazon is a popular choice. Quality for price is good and simple one setting. I'd put a link up but PITA on the phone!!
#9 TDM4ever
TDM4ever
  • 302 posts
Posted 19 July 2018 - 04:35 pm
These?
https://www.ebay.co...._from=R40&rt=nc
#10 Apache
Apache
  • 553 posts
Posted 19 July 2018 - 05:12 pm
Depends on budget I guess Cclivve. Bikevis are expensive and some reports of failures on here but I've had mine on for two years and they've seen some serious rain and are still good....
#11 PICARD
  • 1,744 posts
Posted 19 July 2018 - 06:38 pm
These?
Yuup those. Brackets are a bit mickey mouse but for price / performance I'm happy.
#12 WayneUK
WayneUK
  • 29 posts
Posted 19 July 2018 - 06:42 pm
do you think it could be the switch as the one i have on has 3 wires 1 live each for the lights , i have another switch which only has 2 wires so the live from the spots will go on the same live on the switch?
#13 fixitsan
  • 4,676 posts
Posted 19 July 2018 - 06:52 pm
It's better but unless the original switch was faulty I don't think it should matter
#14 WayneUK
WayneUK
  • 29 posts
Posted 19 July 2018 - 10:36 pm
Ive been looking at theses https://www.ebay.co....efff768b5|iid:1
#15 Latestarter
Latestarter
  • 676 posts
Posted 20 July 2018 - 06:45 am
This is what I done to mine when I had my 900 and it worked a treat..
https://youtu.be/KQIRV1y-Q6E
#16 WayneUK
WayneUK
  • 29 posts
Posted 20 July 2018 - 07:37 am
Did this to mine a while ago but then they stopped working after a week
#17 Cclivve
Cclivve
  • 27 posts
Posted 20 July 2018 - 09:20 am
I bought some cheap Chinese,,will let you know how they go in due course.
#18 peloponezian
peloponezian
  • 20 posts
Posted 02 August 2018 - 10:25 pm
This is the bike.
I use a made by "Ring" light called an Aurora dlr they come as a pair and have the auto switch unit, if needed.  You will not be disappointed with the brightness, Imagine the brightest DLR you've seen on todays cars, Merc, Audis? this knocks 'em into a cocked hat IMHO. 5 x 1.5w that make your 110 main beam look like a 5w standard side light.  I have mounted mine beneath the Headlamp which i have now relayed to be off during the day because its a waste of time next to this. . I have them on a couple of bikes as they come as a pair not cheap at £70 per pair  ish but worth every penny.  Downside is they are so bright you don't want to be using them on full power at night, way too much. I have an LED controller wired in so I can knock it down if needed at night.
Been using them for 5 years no issues at all, fully waterproof and they look like the y belong if you mount them right, a quality lamp
Edited by peloponezian, 02 August 2018 - 10:26 pm.
#19 TDM4ever
TDM4ever
  • 302 posts
Posted 03 August 2018 - 11:21 am
These?: https://www.hids4u.c...ra-BRL0397.html
Edited by TDM4ever, 03 August 2018 - 11:23 am.
#20 peloponezian
peloponezian
  • 20 posts
Posted 03 August 2018 - 09:18 pm
Yes they're the ones at a good price too... sorry cant seem to upload a piccie of them
