Brake Disc Warped
20 replies to this topic
#1 JMC
JMC
  • 257 posts
Posted 20 January 2020 - 09:35 am
So my left front disc on the 4tx is warped so need to source a replacement
in this thread  I found a list of discs from other model's that will fit so anyone got any to add to it so I can widen my search and (hopefully) not get screwed on price
298mm Dia
TZR 250 (3MAI) 89
FZR400 RR (4DX) 92
FZ 400 96
FZR 400 (3TJ1/2/6/7)
FZR 400 (3ENZ) 89
SR 400 (BC-RH01J)
XJR 400 95-
FZR 600 83-93
FZR 600 R 94-95
FZS 600 FAZER 98-03
FZ 750 89-91
TDM 850 91-01
TRX 850 96-99
FJ1200 (3CV/3XW) 88-95
Or the other option is to buy a full set of ebay ones, anyone have good results with something like this set
Hunter S. Thompson.
#2 TKH
Posted 20 January 2020 - 11:51 am
Avoid Chinese disks is all I've heard. Trouble with some of the sellers, they don't tell you the source of the disks......
Did I read somewhere on here you can swap to 9'er disks? Would a wheel including disks be a way to go? Don't know how compatible 9'er wheels or others are with 850's.
Edited by TKH, 20 January 2020 - 11:53 am.
#3 dablik
  • 10,735 posts
Posted 20 January 2020 - 12:40 pm
Only the 9r rear disc will swap over,  pretty sure drewpy had a disc made up for his mk2 from here, i grabbed a set of nearly new Brembo's which were originally fitted to an Aprilia Futura, cant remember year, but would imagine other Aprilias fit also..
#4 Andy25
Andy25
  • 335 posts
Posted 20 January 2020 - 07:10 pm
Bought a pair of Tarazon wavy discs from Amazon back in August £129.99
Not had any issues with them so far
Still on sale 3-4 day dispatch they estimate del - Wed 29 - Feb 5Attached File  20190924_143447.jpg   96.07KB   2 downloads
The Cable ties are not a permanent fixture - was just to get me home. Cos I forgot to tighten the bolt oops
Edited by Andy25, 20 January 2020 - 07:12 pm.
#5 MickC
MickC
  • 404 posts
Posted 20 January 2020 - 07:17 pm
Does it follow then that if a disc is 298mm outer diameteer then the inner diameter and bolt hole spacings are the same?
#6 steve27bha
Posted 20 January 2020 - 10:29 pm
This Amazon item:-
https://www.amazon.c...2/dp/B01JP5XHBY
lists non-Yamaha bikes as well, for the Brembo part 78.B408.A2 (Cagiva, Ducati, Triumph).
The A2 part of the part code seems the significant section, since the 78.B408 appears for different bikes, with another suffix.
Working back from the TDM fitment part number for other disc suppliers may provide further lists of compatible bikes, and searching / Googling the part numbers. I saw Morini Scrambler / Gran Passo 1200 mentioned too.
This item specifies the disc dimensions:
https://www.ebay.com...AYAAOSwwvtb7Z7x
HTH
#7 wicklamulla
Posted 21 January 2020 - 12:39 am
Still on sale 3-4 day dispatch they estimate del - Wed 29 - Feb 5attachicon.gif 20190924_143447.jpg
those discs being completely swept by the pads?
298mm Dia
TZR 250 (3MAI) 89
FZR400 RR (4DX) 92
FZ 400 96
FZR 400 (3ENZ) 89
SR 400 (BC-RH01J)
XJR 400 95-
FZR 600 83-93
FZR 600 R 94-95
FZS 600 FAZER 98-03
FZ 750 89-91
TDM 850 91-01
TRX 850 96-99
JMC  is it deffo warped and not simply gummed up bobbins?
https://www.youtube....qoPqN2GBdw&t=6s
#8 Andy25
Andy25
  • 335 posts
Posted 21 January 2020 - 06:46 am
[quote name="wicklamulla" post="375294" timestamp="1579567163"]those discs being completely swept by the pads?
Not sure if that was due to bolt falling out etc or the new pads ,
refurbished calipers etc
But every thing seems fine now
#9 Bjørge
  • 1,791 posts
Posted 21 January 2020 - 11:11 am
Been there, done that  :rolleyes:
#10 JMC
JMC
  • 257 posts
Posted 21 January 2020 - 01:21 pm
That does make sense so I will check tonight and report back, maybe I'll be lucky and find that's all the problem is  :lol:
Hunter S. Thompson.
#11 dapleb
  • 18,105 posts
Posted 21 January 2020 - 01:47 pm
Also check calibobs not partially seizing.. Is the time of year for that...no point in gettin expensive new discs Android immediately warping them.
If you can't get OEM discs...good luck with what you choose...some real plop out there.
#12 JMC
JMC
  • 257 posts
Posted 22 January 2020 - 09:29 am
Checked the bobbins last night they don't have a hole through them so difficult to move but I tried cleaning with brake cleaner and it made no difference
See attached pic, now if I press on it the disc snaps back the other way and appears warped to the other side but won't center in the middle
Cant attach pic either on phone or pc for some reason
Link to pic https://ibb.co/fnDYcxP
Edited by JMC, 22 January 2020 - 09:39 am.
Hunter S. Thompson.
#13 Bjørge
  • 1,791 posts
Posted 22 January 2020 - 11:06 am
A bit hard for me to imagine what behaviour you're indicating (partly due to limited English knowledge), would need a video or series of pictures.
But as dapleb said, free moving pistons is a requirement - as sticky ones would require a 100.000% straight disc to avoid pulsating brakes. My disc bobbins (MkI/9'er) are not free, nor are discs 100% straight, but after servicing calipers brakes are dead smooth.
Edited by Bjørge, 22 January 2020 - 11:07 am.
#14 drewpy
  • 1,754 posts
Posted 22 January 2020 - 02:03 pm
I used a small G cramp so I could release them
#15 leehenty
  • 5,080 posts
Posted 22 January 2020 - 08:16 pm
Loctite 243 will be your friend, together with a decent torque wrench. I put a spot of tippex on each bolt after torquing, that way it's easier to spot any you missed. Auld age yer know.  :oldgit:
#16 JMC
JMC
  • 257 posts
Posted 30 January 2020 - 12:19 pm
Update...so I ordered seals to do a full rebuild of both of the front calipers and about to pull the trigger on a used front disc for 35 gbp delivered, the seller says it's in good condition so will report back when job is done.
Hunter S. Thompson.
#17 JMC
JMC
  • 257 posts
Posted 08 February 2020 - 10:40 pm
All parts arrived during the week and in the middle of the caliper rebuild, fingers crossed 😆
Hunter S. Thompson.
#18 JMC
JMC
  • 257 posts
Posted 09 February 2020 - 04:24 pm
All done, thank you jesus :)
All seals replaced flushed out all old gunky brake fluid and brakes working nice, 2nd hand ebay disc was perfect, new pads as well
Also flushed out coolant and replaced, changed oil and filter, plugs, and gave her a good going over, a good weekends work even if though bleeding the front brakes after a complete overhaul is a bitch
Can't upload images for some reason   :unsure2:
Edited by JMC, 09 February 2020 - 04:27 pm.
Hunter S. Thompson.
#19 JMC
JMC
  • 257 posts
Posted 16 February 2020 - 06:59 pm
200km or so done so far since rebuild of calipers and replacement disc and all's well, it's nice to have good brakes again :)
Attached File  calibobs.jpg   128.6KB   0 downloads
Hunter S. Thompson.
#20 dablik
  • 10,735 posts
Posted 16 February 2020 - 09:15 pm
Good man JMC, thems lookin nice, did you have to resort to Del boys piston poppin method, they can get jammed in, least you can split the calipers on the originals which helps..dont forget ya bobbinses..
