Fork Oil And Seal Replacement
27 replies to this topic
#21 fixitsan
  • 4,676 posts
Posted 12 April 2019 - 01:45 pm
Here's a 1980's Honda manual showing the fork oil specified is ATF https://www.bobisthe...0613_091940.jpg
The FT500 and XS750 had ATF in forks too
Edited by fixitsan, 12 April 2019 - 02:28 pm.
#22 Favs
  • 4,395 posts
Posted 12 April 2019 - 01:49 pm
ATF for forks, it is a long time since I heard that.  We used to use it in our bikes in the 60's and 70's and not just for light road use, also used it in my MX bikes.
+1
#23 TKH
Posted 12 April 2019 - 02:38 pm
ATF is good for lubing guns if anyone is interested. Careful not to get any on the seals or it my end up deiseling on an airgun when you fire it. ............I'll get my coat :hide:
Edited by TKH, 12 April 2019 - 02:40 pm.
#24 dapleb
  • 18,117 posts
Posted 12 April 2019 - 02:43 pm
Proper furks don't need oil. Girdraulics.
You might find 15w a tad tick in comparison to old pickled onion water but maybe ya won't and since you already gots it, give it a go and report back.
The crazy Frenchman uses ATF and it's never done him any harm....
#25 JMC
JMC
  • 257 posts
Posted 12 April 2019 - 03:29 pm
The right stuff always was ATF, before fork oil came along.
Which fork oil should I use ? A 7.5W of one brand has the same viscosity as a 10W rated other brand, and even a 12.5W fork oil can have the same viscosity as another brand 10W, or even 7.5W.....which leads me to conclude one thing - if there is no standardisation of viscosity, relative to the weight rating, and considering that fork oil performance is directly related to viscosity, not 'Weight' rating, then what we need is an oil that is seal friendly, designed for pressurised hydraulic systems, has low moisture absorption, wide temperature range,and no matter which manufacturer you buy it from it has much tighter viscosity ranges than any fork oil. For example Dexron 2 has an almost identical viscosity across all manufacturers, because it is rated and specified , properly, in terms of viscosity.
You know where you are with ATF, it is a safe to use, standardised viscosity, with a predictable performance range, which is useful.
Here's a table of different viscosities of fork oils - https://s3.amazonaws.com/advrider-photobucket-images/images/J/JakeSabre1_ForkOilCap1.jpg  Do you know which one you need ? Do you buy it by weight rating 'W' or buy lab tested viscosity ? Do you know that one manaufacturer's light oil is the same viscosity as another manufacturers mid weight oil ?
Dexron 2 has a viscosity of 37.5 at 40 celsius, and thins predictably with temperature. Meeting the standards set out for  General Motors Dexron II, Mercedes Benz and Detroit Allison C-3. In fork use, it is of about the same viscosity as Bel-Ray 10W. Possibly a bit too high for cartridge forks, but for TDM forks it's absolutely fine.
Super info there, Thanks  :good:
Hunter S. Thompson.
#26 dandywarhol
Posted 12 April 2019 - 05:34 pm
ATF also has higher anti foaming values than fork oil - it's designed with minimum foam for autoboxes which burn out their clutched if foaming occurs. Ideal for the shitty damper rod fork damping in the TDMs
#27 Studley Ramrod
  • 19,214 posts
Posted 13 April 2019 - 08:46 am
Whale oil beef hooked ! :P
#28 dablik
  • 10,754 posts
Posted 13 April 2019 - 05:47 pm
Thought the crazy frenchman used mint sauce in his forks :huh:
