It took my 2.5A wall chargers about 2.5hrs to bring the units to full charge from half, out of the pack.
Then checking that my phone (a Motog3) charges at 1A from the wall, connected to the 1A port and can say that charging takes place at at least 80-90% the rate of a wall socket, all the way to 100% phone capacity.
You sometimes need t o be a bit careful making these sorts of assumptions.
A 2.5A wall charger has a 2.5A output at peak demand, but there is no reason to assume that the 10400mAh battery charges at 2.5A because of the fact that it has it's own inbuilt charging circuit which could be charging the cells at 1.5A instead
Typically the cells inside these devices are from the lower end of the quality spectrum, with very low peak C ratings, which in turn means that their charging current has to be limited.
A reasonably reliable way to measure instead (if you can't actually measure the current leaving the wall charger, is just to use a plug in power meter, the sort with an LCD display which are sold to help people use electricity more efficiently......assume a 90$ efficiency for the wall charger and 90% efficiency for the charging circuit inside the powerbank itself and you'll get pretty close to the number of Wh being stored.
Another thing is that 10400mAh is a bit meaningless on it's own. What voltage is that measured at ? If the cells are Lithium ion then you can assume a nominal 3.6V per cell......so is it then 10400mAh at 3.6V ? Presumably it is so thats about 36Wh. What if the cells inside are NiMH cells and it's 10400mAh at 1.2V, then there's only about 12Wh. I prefer to think of capacity in terms of Wh and not just mAh.....A plug in charger in the back of a consumer power meter can display Wh easily....I would expect to see at least 42Wh being used to charge one of those puppies anyway !
