Niner Woes
#61
Posted 15 April 2019 - 09:19 pm
#62
Posted 16 April 2019 - 05:13 am
- the first 10 clicks are also bumpy
- when stalled and restarted, I think it will stall again if not given gas in neutral, too
- should be a corresponding error code on the dash IIRC (which was there first time I checked but did not show up ever since, also no other codes right now)
If it's still possible the switch is misbehaving I will have to check that out also, but I don't know how I would do that.
EDIT:
So HT lead replacement and airbox mod did not help. The latter feels nice while the bike works though. What's strange is that when I disconnected the coils for safety reasons while wrenching, I forgot to reconnect the LH one and it threw a code immediately upon restart. So shouldn't I see a code when it acts up?
Also how involved would be spark plug replacement after lifting the tank? I have some working spares at home...
Edited by Atesz792, 16 April 2019 - 07:01 am.
#63
Posted 16 April 2019 - 07:11 am
....and it couldn't be this problem, an original, faulty ECU? : https://www.tdm-yama...t.org/?page=ECU
#64
Posted 16 April 2019 - 07:34 am
EDIT:
Now that I think about it, if it was a fuelling issue, it would not smell like a puddle of gas right? But it does when it quits...
EDIT #2:
Found CB's excellent service guide and think I should be able to perform plug change.
Question is, is plug spanner included in factory toolkit, and if not, then exactly what type should I buy?
EDIT #3:
Valves out of spec maybe? Now that's just a wild guess, but thought I'd ask anyway...
Edited by Atesz792, 16 April 2019 - 08:45 am.
#65
Posted 16 April 2019 - 09:00 am
Wonder if it might be the Cold Start Mechanism (CSM) sticking.
#66
Posted 16 April 2019 - 09:32 am
Just called an official Yamaha dealer near me and he said it sounds like a TPS issue! And the recall hasn't been done on it yet. Will have to make an appointment...
#67
Posted 16 April 2019 - 12:47 pm
Just thinking the same.
#68
Posted 16 April 2019 - 12:57 pm
You say " would not smell like a puddle of gas". Are you you saying you smell fuel? As a guess, are both injectors working? Are the injector seals ok? What about loose muck in the fuel lines - works ok when there's no big demand but when you add a demand it blocks? I'm clutching at straws a bit here but going though things that have affected me on vehicles in the past.
Is there a fuel filter in there somewhere? before the regulator? Is it the regulator? Fuel pump? Sorry if you've already tired these.
#69
Posted 17 April 2019 - 09:46 am
EDIT:
Got an appointment for the recall: almost a month from now. Can't fathom why PO would not have had something so important (&free) done.
So happy I didn't sell my faithful little GS.
Edited by Atesz792, 17 April 2019 - 03:39 pm.
#70
Posted 18 April 2019 - 05:23 am
Sounds like the CO has reset to -128 with the duff battery. Glowing headers, overheating.
Posted 13 May 2019 - 06:57 pm
TPS replacement seems to have cured my issues.
Lucky there was a recall, else it would have cost me a small fortune.
Some keywords for my fellow Hungarian riders who may experience this in the future and do a search: Yamaha, alapjárat, elmegy, leáll, kormol, füstöl, gyújtás, túlmelegszik, benzin, kifogy. Fojtószelep szenzort kellett cserélni, volt rá visszahívás.
#72
Posted 13 May 2019 - 10:40 pm
UPDATE
we are happy for you. Did you have to pay for the new TPS or did Yamaha provide it for free of charge?
#73
Posted 14 May 2019 - 06:26 am
Totally free of charge. Even got a cup of coffee while waiting, nice folks.
#74
Posted 14 May 2019 - 09:55 am
a wedge of cake too?
#75
Posted 14 May 2019 - 01:00 pm
Chancer
Posted 14 May 2019 - 06:32 pm
Ya don't ask, ya don't get.
#77
Posted 15 June 2019 - 09:21 am
Also had similar symptoms for the last 15k miles or so.
I never have any issues starting the thing, but getting to the lights clutch in or even just in traffic it will cut out (not always). It also happened at quite an inopportune moment filtering through the Blackwall Tunnel yesterday.
I had a similar issue with an old SV650, which I also never got round to fixing. But this time perhaps I will.
I have done the amalgamating tape mod in the past I was suffering severe issues with arcing HT leads (losing all power, having to pin the throttle to get out of danger; nothing, nothing, nothing, everything). Tape mod ostensibly fixed it entirely.
Another item that could be related to this is my idle is beyond erratic. It really surges. Never close to stalling but probably from 1300rpm up to 1800rpm +.
Potentials:
- Throttle position sensor. This bike is post recall year (57MY) but with the hunting idle I wonder
- Old spark plugs, they're probably over 20k miles now. There are some waiting on the shelf.
- I made a half arsed job of wrapping the HT leads and now the problems are intermittent/the leads were on their way out and I should just have replaced them
- Side stand switch
- Corroded connector, somewhere (quite likely that this will be the case as she's run daily through any weather and I store her outside for character building)
Anyone got any other pointers? Battery terminals are not lose
I'm also looking for a way to prioritise my list. I am interested in methods that are cheap, non time consuming and have a good chance of fixing my issue! That would be the day
#78
Posted 15 June 2019 - 09:53 am
Start off replacing the leads if they were past best before taping them up,plugs and lift the tank to pull all the connectors and clean em then spray, that includes the ecu, my choice is ACF50, other lubes available, good chance you have a connection problem ? seems to happen on bikes used a lot and stored outside, hope you get it sorted.
btw..Magnecor will take an order over the phone.
Edit... the side stand switch is easy to repair as often it's just a corroded wire needs soldering.
Edited by dablik, 15 June 2019 - 09:56 am.
#79
Posted 15 June 2019 - 10:25 am
This was about a different problem but might provide some clues for you. At least their bike got sorted.
#80
Posted 17 June 2019 - 09:44 am
I'll methodically work my way through all of that, I'll get back to you if I get to the bottom of it. I'll likely do it all at once so unless something is clearly broken I may not be able to give a conclusive answer as to what exactly causes it if I do indeed fix it
