L E D
9 replies to this topic
#1 Favs
  • 4,395 posts
Posted 07 June 2019 - 04:55 pm
Post MOT ......
H7 Led lamps fitted (bulbs).
Correct focal length & light source size
Testing over 2x 300 miles overnight trips on a mixture of A, B & M class roads in the near future.
I'll be taking the H7 halogens with me in case the LED are NFU/difficult for other road users.
#2 TDM4ever
TDM4ever
  • 302 posts
Posted 07 June 2019 - 05:35 pm
Looking forward to your review  :tup:
#3 Rallyist
  • 3,251 posts
Posted 07 June 2019 - 05:38 pm
Post MOT ......
More info needed ..... please
#4 Favs
  • 4,395 posts
Posted 07 June 2019 - 06:04 pm
Search banggood for C6 LED Graham.
It is possible to move/remove the mounting plate. I removed them to put my 8mm clip spacers on, this also enabled the correct repositioning of the mount regarding orientation and distance from the light source. I must point that the lamp mounts were in the correct focal position b4 moving them.
I may experiment with mount rotation  ;)
#5 Andy25
Andy25
  • 335 posts
Posted 09 June 2019 - 06:07 pm
Where are you planning on Testing these bulbs ?
More interested in LED vs Halogen - on a mk 2 any improvement is welcome
As you already know further North in Summer we don't really have DARK
NIGHTS so its just an issue in the Colder month's ( so most of the time then )
Andy
#6 Favs
  • 4,395 posts
Posted 09 June 2019 - 11:17 pm
Yeah our days are longer than those southern ones.........
Initial testing will be in the small hours between 23:00 and 03:00 ish some time next week, between Durham City and Farnborough (Hampshire). After that I'll be testing them in FR n IT. Probably not full moon so should be full dark yarrrooooooohhhh
I had 35w HID in my 4tx - a lot better than stock lamps.
#7 chrisr
  • 1,745 posts
Posted 12 June 2019 - 10:22 pm
So I’ve just received a pair of these......how do you remove the mounting plate? I’ve tried twisting and it turns, but doesn’t come off!
#8 Favs
  • 4,395 posts
Posted 13 June 2019 - 07:10 am
For me, gently turn/pull with pliers worked.
#9 Favs
  • 4,395 posts
Posted 25 July 2019 - 08:23 am
Update
High beam is v good & much better than the previous LED  I had.
Dipped beam is OK - same beam pattern (not a suprise) but seems to light up the road better (not farther), than the HID i had fitted. No angry feedback from otgher road users so far.
Cooling fans seem effective so far.
HTH
#10 Bjørge
  • 1,791 posts
Posted 25 July 2019 - 09:27 am
Update
HTH
Good report! Ordered a set from Banggood, preparing for the dark late summer and autumn...
