For my 2005 TDM900. Can I buy the much cheaper non Yamaha original part
as a replacement. That is a complete new fuel pump. They look different, but suppose if they share the same connection template they may well be interchangeable.
Fuel Pump Change
Started by
Polyampan
, Jun 15 2019 02:12 pm
2 replies to this topic
Posted 15 June 2019 - 02:12 pm
Posted 20 June 2019 - 01:55 pm
Main thing is to check the diameter of the hose connections.
Does the 900 have a separate fuel pressure regulator?
Maybe you can post a picture of, or a link to the one which you intend to obtain?
Edited by MipeTDM, 20 June 2019 - 01:57 pm.
Posted 29 August 2019 - 07:08 am
I "temporarily" put on a car pump Biltema 52-260, requires a small grind as it is longer than the original, the connections are the same.
