Is This Bugger An Mki Part?
18 replies to this topic
#1 Bjørge
  • 1,791 posts
Posted 28 May 2020 - 03:56 pm
Changed tyres, chain/sprocket, fitted heat grips, changed clutch.
Found this on the ground...
#2 dapleb
  • 18,104 posts
Posted 28 May 2020 - 04:00 pm
Don't immediately recognise it. Whassa other end look loike? Just blank rubber plug?
#3 Bjørge
  • 1,791 posts
Posted 28 May 2020 - 04:28 pm
Yup. No oil, just a bit of black, dry dirt all over it.
#4 dapleb
  • 18,104 posts
Posted 28 May 2020 - 04:35 pm
Got givi rack?
#5 drewpy
  • 1,753 posts
Posted 28 May 2020 - 05:16 pm
i thought a givi bung to go in the rack on the side. one of mine keeps coming off.
Should be a pointy bit on it too
#6 Bjørge
  • 1,791 posts
Posted 28 May 2020 - 06:16 pm
Yeah, thought about it. May actually be, but not from my current box.
..and thinking of it, this one is too big..
#7 Studley Ramrod
  • 19,202 posts
Posted 28 May 2020 - 08:25 pm
That son, is a thing of purpose. :oldgit:
Don't recognise is as a mk1 part.
#8 leehenty
  • 5,080 posts
Posted 28 May 2020 - 08:37 pm
Centre stand buffer ?
#9 Favs
  • 4,391 posts
Posted 28 May 2020 - 08:59 pm
Seat frame bump?
#10 wicklamulla
Posted 28 May 2020 - 09:28 pm
it's a sloice of black forest gateaux.
#11 Bjørge
  • 1,791 posts
Posted 29 May 2020 - 05:56 am
I'll check that one!
Seat frame bump?
Too small, I believe
Ok, if No MkI use found I will eat and report if you're right 😁
#12 dapleb
  • 18,104 posts
Posted 29 May 2020 - 06:59 am
Could it be the cap for your smergel paste? Difficult to obtain here but popular in Norway I've heard.
#13 Favs
  • 4,391 posts
Posted 29 May 2020 - 08:50 am
Bertie Basset's hat
#14 wicklamulla
Posted 29 May 2020 - 09:41 am
ahhhhh it is a TDM 900 riders contraceptive device.
#15 Bjørge
  • 1,791 posts
Posted 29 May 2020 - 01:09 pm
Don't think I have it  :P
Bertie Basset's hat
...but how did that make it into the MkI ? It was the now gone 9er that was brought from GB . . . maybe they have been initmate ?  :D
Like a P-plug ? ...must be for a very young one, then....
#16 curlylegend
curlylegend
  • 305 posts
Posted 29 May 2020 - 08:40 pm
Is there a prize for getting the right answer ?
#17 leehenty
  • 5,080 posts
Posted 30 May 2020 - 07:39 am
Too small and the usual item used is tapered sometimes with bumps.
#18 Bjørge
  • 1,791 posts
Posted 30 May 2020 - 08:48 am
As I had a coffee this morning on the balcony considering the quest for a prize it struck me: It's from a vehicle, but not MY vehicle....
3 years ago I made this front yard with a quite steep driveway up to the drivepath
And I found it on the ground next to my MkI 😁😂
Edited by Bjørge, 30 May 2020 - 08:53 am.
#19 Gdogg
Gdogg
  • 1,160 posts
Posted 30 May 2020 - 09:10 am
I was just gonna say that. LOL !!
Edited by Gdogg, 30 May 2020 - 09:11 am.
