Had To Happen
6 replies to this topic
#1 leehenty
  • 4,125 posts
Posted 27 July 2020 - 04:09 pm
Brother has dropped his Crosstourer in a car park. Broke gear and clutch levers off. Three strong men picked it up and it came home on a AA truck.
#2 dapleb
  • 16,779 posts
Posted 27 July 2020 - 04:12 pm
Owwwwww bottoms
#3 dablik
  • 9,280 posts
Posted 27 July 2020 - 04:14 pm
Oops, you did say they are heavy..
Quad 900 Silver Laser duo tech pipes-Scott oiler-Engine crash bars- Radiator mounted see me ring LED's-Datatool system 3 alarm -Centre stand- Extender fender-Renthal bars-Handle bar risers-Mirror extenders-BMW GS Handgaurds-Acumen uprated horn & Nautilus-Stainless steel Radiator guard-Givi wing rack-OEM screen-Yammy touring screen-MRA Vario-MRA Double bubble cut down for fast as fk riding-Tiger screen-Tank protector-Stomp grip panels-Optimate lead
1991 MK1 in need of some TLC watch this space  :) Sorted and on the Road Mick :P :P it's the bike that Jack built ;)
#4 leehenty
  • 4,125 posts
Posted 27 July 2020 - 04:57 pm
It started to go over so he jumped off smartly,but couldn't pick it up.
#5 steve27bha
  • 569 posts
Posted 27 July 2020 - 10:30 pm
I remember straddling one on its sidestand in the showroom and failing to shove it upright. I had grippy shoes on too, but felt they would slip before I got the necessary leverage. Dunno what it would be like on a sandy or gravelly road surface!
Hopped off sharpish and put it onto the "Never in a million years" list.
CBX750FE in reserve; Cagiva N90 125 in bits
#6 Navigator1946
Navigator1946
  • 57 posts
Posted 28 July 2020 - 06:07 pm
At least it went down on the left side. More to damage on the right! I'm speaking from personal, painful, expensive experience!
Edited by Navigator1946, 28 July 2020 - 06:08 pm.
2008 TDM900 in beautiful black.  Fender extender, after market Bullster touring screen, radiator guard, RM-G crash bars, 12V/USB socket, Oxford heated grips, Bagster tank cover, centre stand, E22 Givi panniers, standard exhausts. Beautiful Acerbis hand guards. <p>2015 Honda Crosstourer Highlander dct. Fabulous bike, but getting heavier as I age. The 9er is its replacement, eventually.
#7 leehenty
  • 4,125 posts
Posted 28 July 2020 - 09:04 pm
gear lever at £75  is expensive enough
