Bulb Replacement
15 replies to this topic
#1 skedaddle
skedaddle
  • 52 posts
Posted 15 October 2018 - 08:28 pm
Would anybody be able to steer me in the direction of a replacement bulb for the small light on the front of the 850.  Not sure what it;s called.
I checked mine as it starts flickering after a while and is generally useless and it doesn't appear to be lighting fully and I've never seen a bulb like it.
#2 wicklamulla
Posted 15 October 2018 - 09:08 pm
looks loike thas a funky replacement LED type.  There may be info. stamped on it which will help you.
#3 JMC
JMC
  • 257 posts
Posted 15 October 2018 - 09:19 pm
I've ordered These for my 850 to get that light a bit brighter if that helps
But this looks like a good deal too https://www.gearbest...tml?wid=1433363
Edited by JMC, 15 October 2018 - 09:22 pm.
Hunter S. Thompson.
#4 Gdogg
Gdogg
  • 1,163 posts
Posted 16 October 2018 - 05:32 pm
It's your "side light" or "parking light" or whatever floats yer boat skedaddle.
I changed my filament type lamp for a LED one 4 years ago and still going strong, mines not quite so elaborate as your one !!
Edited by Gdogg, 16 October 2018 - 05:34 pm.
#5 skedaddle
skedaddle
  • 52 posts
Posted 16 October 2018 - 05:57 pm
Cheers JMC the Chinese ones look like a bargain, 10 for 3 quid! And they look fairly similar.
Cheers Gdogg, its fairly elaoborate alright, the front of the bulb is angled upwards so it points straight out even thought the bulb fitting makes the bulb point downwards. Pretty nifty for a bulb really.
#6 JMC
JMC
  • 257 posts
Posted 25 October 2018 - 07:54 am
So my bulbs came and they are a little bit too long, the light cover won't go back on so I'll have to find shorter ones
Not a big deal as I've put these ones in the cars and they make a huge difference
Hunter S. Thompson.
#7 dablik
  • 10,747 posts
Posted 25 October 2018 - 08:17 pm
I've replaced mine with one of these, remove the bulb holder to fit it, i snipped the wires of the connector to retro fit this one.
#8 skedaddle
skedaddle
  • 52 posts
Posted 25 October 2018 - 08:49 pm
I went with a plain halfords incandescent bulb. this is flickering too so it seems i have a loose wire or something somewhere. bollox.
#9 madmopedracer
madmopedracer
  • 473 posts
Posted 25 October 2018 - 09:22 pm
flickering is good it makes you more viable than a constant light.
i think there was an accessory back in the 70s to do this
#10 ramo
ramo
  • 1,177 posts
Posted 25 October 2018 - 09:29 pm
or fit a short one like these
https://www.ebay.co....YNLbX:rk:1:pf:0
#11 JMC
JMC
  • 257 posts
Posted 25 October 2018 - 10:52 pm
Ive 2 of those and was looking at doing the same :)
I'm off next week so might get a chance to do it then
Did you remove the holder from the front or had you to remove the fairings
Edited by JMC, 25 October 2018 - 10:54 pm.
Hunter S. Thompson.
#12 dablik
  • 10,747 posts
Posted 26 October 2018 - 08:07 am
I removed the fairing on mine as i was swapping it anyway, the mk2 is a bit more awkward to remove though so if you can get access all the better.
Edit... I suspect you may have to remove anyway as you will need a bit of room to resolder the wiring.
Edited by dablik, 26 October 2018 - 08:09 am.
#13 JMC
JMC
  • 257 posts
Posted 07 November 2018 - 09:47 am
So I was bored last night and took one on those led bulbs apart and soldered if back together to make it fit, not sure if it's too bright till I get the bike out again but it's now a lot brighter than stock :)
Sorry pics are sideways I'm on the phone
Edited by JMC, 07 November 2018 - 09:50 am.
Hunter S. Thompson.
#14 Bjørge
  • 1,791 posts
Posted 07 November 2018 - 09:58 am
Good work !
I'd reinforce those little boards, though, solder isn't the most durable material when subject to vibrations....
#15 JMC
JMC
  • 257 posts
Posted 07 November 2018 - 10:03 am
Good work !
Yep I'll mix up a bit of araldite tonight to keep it together  :tup:
Hunter S. Thompson.
#16 TDM4ever
TDM4ever
  • 302 posts
Posted 08 November 2018 - 09:00 am
Cool, I will try the same  :good:
