Ecu Remapping On Tdm 900
17 replies to this topic
#1 surftdm850
surftdm850
  • 14 posts
Posted 21 October 2017 - 12:35 pm
Hi,
Has anyone a simple way of remapping ecu unit on tdm 900. to improve fuel consumption
#2 dablik
  • 10,735 posts
Posted 21 October 2017 - 01:37 pm
If you mean cheap surf then i dont think so, you gotta spend fella far as i know, search the forum, fixitsan has remapped his to good benefit.
#3 Studley Ramrod
  • 19,202 posts
Posted 21 October 2017 - 01:40 pm
Didn't improve his consumption though.
Thought the 9'er was a very economical bike anyhoos.
#4 muddy
  • 2,969 posts
Posted 21 October 2017 - 02:35 pm
For a 900 I can't see there's much room for improvement. Riding normally, operating mostly in the 3k to 5k rpm range, I regularly get 60+ mpg.
#5 fixitsan
  • 4,668 posts
Posted 21 October 2017 - 03:38 pm
You could add a resistor in parallel with the air intake temperature sensor to lean it out even more at steady speeds....but I wouldn't go too far or you risk burning valves/plugs. Calculating the correct resistor value to find the best average change is time consuming and not very good when the air temperature changes quite dramatically either
I had mine remapped for various benefits at Samios - http://www.ecu-flash...yamaha/tdm-900/
If you speak to them then they'll be able to tell you how to remap for fuel savings. They would almost certainly be able to do it, if it can be done. You need to send your ECU (and payment of 250 Euro) to Greece and it also needs to be of a type which can be reflashed and isn't just a single flash unit. Samios (or whoever else you find to do it) can tell you from a photo of the product label stuck on the ECU if it is even possible. They have a book from Denso which they cross reference it with.
You can do it yourself too, there are tools available for about £150, but that's very deep water and it pays to buy a backup ECU, just in case.
The better option might be just to take your time, turn the throttle more slowly which reduces the rate of acceleration fuel enrichment, which is often introduced more if you turn the throttle quickly as opposed to turning it slowly. The reason that rotating the throttle from 0-100% in 2 seconds instead of 0.5 seconds is interpreted differently, is because the ECU assumes that when you turn the throttle quickly you intend to be accelerating harder than if you rotate it steadily. This TPS sensor rate volume adjustment can add up to a lot of fuel if you re switching from full to none throttle frequently.
You haven't said what your MPG is at the moment. Is that with luggage ? are the tyres properly inflated ? do you ride a lot in wet and windy weather ?...these all make a difference.
If I tried hard I could get as little as 135 miles from a tankful, now with my remap i can get it down to 120 miles. in both cases I can still get 200 miles if I take it easy, and if I try to get even more I would think it would be just as quick if i went in the car, or used a donkey ;)
Edited by fixitsan, 21 October 2017 - 03:52 pm.
#6 surftdm850
surftdm850
  • 14 posts
Posted 22 October 2017 - 09:44 am
Thanks for all the responses,
Seems remapping has little or no gains,unless it improves performance ?
#7 fixitsan
  • 4,668 posts
Posted 22 October 2017 - 01:53 pm
It's a bit of both worlds, just because you get a better response or a faster bike once it's remapped there is nothing to say you have to use it. Making efficiency improvements mean that for any given load (EG 70mph in 6th gear) a more efficient engine/intake/exhaust system will use less fuel to achieve the same thing.
A new air intake filter might be a way to go.
#8 JBX
Posted 23 October 2017 - 12:30 am
Never heard of anybody remapping an ecu to lower fuel consumption !
Or get a CG125...
Internal combustion engine efficiency is a strange thing, and on standard cars/bikes it's just a joke.
Best efficiency is 50% on some big (15m high) two-strokes diesel marine engines that have a fixed, low rpm and many other special characteristics.
On cars it's between 15-25% (best on engines with variable intake valve) and on bikes its even lower. You cannot have a good efficiency and a variable rpm engine.
That said there are many ways to improve efficiency, but not ecu remapping. The best known way is to put a turbo-charger, unfortunately it's not recommended on bikes. Other ways are variable intake valves, electric valves (camless engines), variable compression ratio, inhibiting cylinders on multi-cylinders engines, etc.
All theses efforts are worthless when comparing with an electrical engine ! :unsure2:
Edited by JBX, 23 October 2017 - 01:16 am.
#9 fixitsan
  • 4,668 posts
Posted 23 October 2017 - 07:55 am
The last couple of paragraphs on the following page suggest checking the O2 sensor. My previous description of the aging process wasn't complete, i didn't take into account the effect of an aging heater in the sensor itself, which would cause an artificially low output signal, read by the ECU as a lean mixture, which then causes more fuel than normal to be burned in order  to restore the sensor's output.
http://www.autotap.c...gen_sensors.asp
Here's the voltage output graph of a typical O2/lambda sensor which shows just how narrow it's linear range of operation is ! http://400ford.info/images/o2grph.jpg
EDIT - as far as I know the 900 uses the O2 sensor only during cruising, you can have poor economy even with a healthy sensor if you are throttle heavy when not in steady cruise. But if the economy is terrible and most of the riding is done in cruise then I would consider at least examining the sensor to make sure it is clean (blow it out with an air duster ? rinse with paraffin, petrol or naptha ?)
Edited by fixitsan, 23 October 2017 - 08:13 am.
#10 Nog
Nog
  • 512 posts
Posted 23 October 2017 - 08:51 am
To lower mpg the best option is a smaller rear sprocket to change gearing.
As above the TDM is a pretty fruggal engine if  ridden carefully and not bad even when hammered.
#11 Studley Ramrod
  • 19,202 posts
Posted 23 October 2017 - 09:14 am
:wifgeni:  Mainly because his avatar shows he looks loike he knows what he's talking about.  :good:
#12 Nog
Nog
  • 512 posts
Posted 23 October 2017 - 11:36 am
If only that was true  ;)
#13 surftdm850
surftdm850
  • 14 posts
Posted 23 October 2017 - 11:43 am
Going of what fixitsan posted
Replacing air filter and checking o2 sensor cleaning or replacing it,
There is a diagnostic setting on the bike where you can adjust lean or richer settings on each cylinder.
Maybe that is worth looking into?
#14 muddy
  • 2,969 posts
Posted 23 October 2017 - 02:44 pm
You haven't written what mpg you're getting and how you ride.
#15 surftdm850
surftdm850
  • 14 posts
Posted 02 November 2017 - 11:51 am
I am using 6.78litres for 52.3 miles.This is short runs in urban area ,max of 5 miles before stopping.My riding style is mostly easy on the throttle.
#16 muddy
  • 2,969 posts
Posted 02 November 2017 - 03:00 pm
Short urban trips like that are a poor indication of the bikes overall fuel consumption. I had a similar commute and got crappy mpg. The bike hardly has time to warm up. The TDM is a leggy big twin, it likes to stretch.
Edited by muddy, 02 November 2017 - 03:29 pm.
#17 dablik
  • 10,735 posts
Posted 02 November 2017 - 06:25 pm
I'd say that's pretty normal around town at least in my experience.
#18 Nog
Nog
  • 512 posts
Posted 06 November 2017 - 09:26 am
Doing some head scratching (not working in litres here) and it works out as 35mpg which in my experience is a little poor for a TDM.  When I used to commute into London on the TDM I would routinely manage around 170 miles to the light flashing, which at a guess is around the low 40's mpg.
As Muddy says though, I guess the bike hasn't had chance to get into it's stride as my commute was more like 10-15 miles, so enough time to warm up and get a decent average consumption.
