Ceramic Bores
17 replies to this topic
#1 thelodger
thelodger
  • 150 posts
Posted 14 December 2017 - 10:14 am
Just  a query out of interest. I know my 9er has ceramic bores so will never need topping up with oil ( fingers crossed )
.....but why is it so effective ?
.......how does it work?
.........does it run hotter/ cooler than cast iron liners etc ?
Is this the same as the Nikasil bore that I've heard of ?
Nigel
#2 Studley Ramrod
  • 19,213 posts
Posted 14 December 2017 - 11:01 am
It's prolly more to do with the fact that the liners are alloy so they expand at the same rate as the alloy pistons allowing for tighter tolerances. Alloy liners need the ceramic coating to prevent premature wear.  Steel/iron liners expand more than the alloy pistons so the tolerances atwixt bores and pistoons on 8fiddlys are greater.
Yes, nikasil is a ceramic coating, think it's used more in twostroke engwins though.
#3 Gauntlett
Gauntlett
  • 77 posts
Posted 14 December 2017 - 01:12 pm
BMW K's and I think R's have had nikasil bores for years, run forever
#4 Favs
  • 4,394 posts
Posted 14 December 2017 - 03:43 pm
Gilera Saturno Bialbero nikasil too
#5 dandywarhol
Posted 14 December 2017 - 04:06 pm
As above but they will still use some oil - that's not a bad thing as it helps premature wear of the pistons
#6 harvey krumpet
harvey krumpet
  • 2,050 posts
Posted 14 December 2017 - 08:08 pm
Oh, I thought this thread would be about Royal Doulton collectors.
#7 madmopedracer
madmopedracer
  • 473 posts
Posted 14 December 2017 - 09:21 pm
brothers mk1 guzzi lemans had them
#8 dandywarhol
Posted 15 December 2017 - 11:25 am
My 1967 Yamaha TD1C has them. Piston/bore clearance of 0.04mm - on a race engine   :pimp:
#9 JBX
Posted 21 December 2017 - 04:36 pm
Engines with fuel injection require ceramic coating because O2 sensor / catalytic converter fail quickly in case of burned oil contamination.
As it is also more expensive the manufacturers didn't bother to use this technology on carbed engines.
#10 dapleb
  • 18,114 posts
Posted 21 December 2017 - 04:43 pm
They ignored the problem until they no longer could ... Crapolific converter
#11 Quartermaster
Quartermaster
  • 927 posts
Posted 23 December 2017 - 08:10 am
my K100 had nikasil bores, Certainly didn't stop the oil running back past the rings when parked on its side stand. The resulting smoke on take off was very impressive.
#12 fixitsan
  • 4,671 posts
Posted 23 December 2017 - 08:28 am
Or until the regulations stopped them from using it as a fuel efficiency move ;)  https://drivetribe.c...OSDqNRbA_yQazOg
Cheeky F1 teams !
#13 JBX
Posted 23 December 2017 - 12:09 pm
Now we know why the 850 offers superior performance ! ;)
#14 dandywarhol
Posted 23 December 2017 - 05:06 pm
Was that not caused by oil running past the intake valve stem oil seal running into the bores overnight?
Hmmm, not many automotive engines use ceramic/nicasil bores and they've had catalytic converters for more than 20 years  ;)
#15 Quartermaster
Quartermaster
  • 927 posts
Posted 23 December 2017 - 08:37 pm
Well it only did it when the bike was canted over on its side stand and so I'd assumed that as the engine was lying on its side, oil under the piston found its way past the rings but you are probably right Dandy. I never bothered to research it as I absolutely hated the bloody machine and sold it asap!
#16 fixitsan
  • 4,671 posts
Posted 23 December 2017 - 08:53 pm
Mine did the same. On the sidestand the head was on the left and lower than the sump.... I thought it was leakage past the rings too, but then again the folk on the forums said it was valve guides too.  I never kept it long enough to find out
#17 dandywarhol
Posted 24 December 2017 - 12:51 pm
The inlet valves are higher - wonder if they still smoked when parked on the mainstand
#18 fixitsan
  • 4,671 posts
Posted 24 December 2017 - 01:29 pm
Apparently not as much. I did try it with mine once and it wasn't quite as spectacular a smoke screen, but if parked on the sidestand overnight the smoke could have hid a platoon of marines
