Restoring 4Tx....
Posted 17 December 2017 - 06:47 pm
Posted 17 December 2017 - 07:29 pm
The later 850 mirrors are def an improvement.
Posted 17 December 2017 - 07:51 pm
I think item 44 is an M5 wellnut. Easy to get off ebay if it is.
Posted 17 December 2017 - 08:50 pm
Looks loike ya made a good start!
My TDM world revolves around 96 - 98 dappers before the namby mods. I didn't know later 4tx had different mirrors. I'll have a mooch...thanks
Posted 17 December 2017 - 08:56 pm
As with the mirrors I didn't know the screen type fasteners were called well nuts. Not a well nut Studley. It's a stepped metal spacer and NLA from Yamaha. Like a 6mm and an 8mm washer glued back to back. It's been missing for years but I want it right when finished.....
Posted 17 December 2017 - 09:09 pm
Ah right, I know what you mean, I might one in my TDM 8fiddly jar, I'll have a look and let you know.
Posted 18 December 2017 - 01:47 am
Posted 11 November 2018 - 12:50 pm
Any suggestions for decrudding a 112000 miles in all weather 4TX engine to a clean enough standard for painting ? Reluctant to strip it as it's in good order..
Posted 11 November 2018 - 01:03 pm
Never done a bike engine before but for a car I did:
pressure wash the main gunk off.
Degrease to remove the thin film of grease left
Remove flaking paint and repair damaged areas
Prep for paint
Posted 11 November 2018 - 01:04 pm
Wow! You're a trained painter ? What kind of equipment are you using ?
Posted 11 November 2018 - 01:25 pm
Prep for paint
Similar thinking TKH...cheers
Posted 11 November 2018 - 01:36 pm
Never painted before Bjorge. Auto elec by trade so I know lots of guys with empty weekend workshops. I just talked a lot and listened more to the advice of a painter I know. Preparation is everything. I bought a 45 quid Spray gun from Screwfix and practiced for a while with metallic and lacquer. Once you've worked out the gun settings for a given product the paint application was quite easy. Prepping is key. The frame took 20 hrs to prep after being blasted....wish I'd had a go years ago.
Posted 11 November 2018 - 01:57 pm
Very nice Apache, looks good
Posted 11 November 2018 - 06:14 pm
Lookin' good there Apache.
Posted 12 November 2018 - 04:59 pm
those nuts and top hat look like a parts bin item. My 1987 fz600 uses those.
if you google and ebay the part numbers, you usually come up trumps
#16
Posted 12 November 2018 - 05:19 pm
You're right Drewpy, that usually works but that top hat spacer isn't out there. Get one cut I suppose. Nuts are available. I'll just have to pay a fiver apiece I guess.
#17
Posted 12 November 2018 - 05:25 pm
And tells me to do the same to every panel all over.
Bit odd to a rookie but apparently when the decals and a coat of clear go on it'll come up gradely 🤔....
#18
Posted 12 November 2018 - 05:59 pm
Yea it seems counter productive but it seems that's what they do !
