Led Bulbs.
7 replies to this topic
#1 Riggers
Riggers
  • 531 posts
Posted 20 October 2017 - 12:19 pm
Hi guys,
Does anyone know how the brightness of LED bulbs is measured? I ordered a cheapo  stop/tail light bulb off Fleabay which, when fitted, was nowhere near as bright as the standard jobbie.
The description is mesmerizing......
http://www.ebay.co.u...872.m2749.l2649
Just wondered what I SHOULD have ordered to get the same brightness as a normal 5/21w type?
Cheers all
Riggers
#2 dablik
  • 10,757 posts
Posted 20 October 2017 - 12:38 pm
Riggers i think you may need to drop an email to these chaps, while more expensive i think they will have the info you need.
#3 Studley Ramrod
  • 19,214 posts
Posted 20 October 2017 - 12:41 pm
Brightness is generally measured in lumens or abbreviated to lm.  In the case of the ebaygum wans, that's 300lm.
#4 Riggers
Riggers
  • 531 posts
Posted 20 October 2017 - 04:45 pm
Thanks guys.
#5 dmmsta
dmmsta
  • 3,627 posts
Posted 20 October 2017 - 08:02 pm
That also reads like it's a single brightness unit.  Unless it dims when no brake is applied.
Roughly speaking
Tungsten = 15 lm/W
Tail = 5W x 15 = 75lm
Stop = 21W x 15 = 315lm
That implies either the LED bought was a dud, or the website I found the above is lying somewhat
#6 JBX
Posted 20 October 2017 - 10:42 pm
A "white" LED is actually a blue led with a yellow re-emitting coating. This gives a kind-of white/bluish light with a weak red part.
When you put this kind of led inside a red transparent casing like the stop-position light at the rear, most of the light is blocked as only the (weak) red part of the light go thru the casing unfiltered.
It's better to put a red LED bulb in this case.
White and blue LEDs are also known to output too much ultraviolet radiation which is not good for the eye.
Edited by JBX, 20 October 2017 - 10:44 pm.
#7 TDM4ever
TDM4ever
  • 302 posts
Posted 21 October 2017 - 08:20 am
True, but the difference is not that big in real life. The white LEDs are often much bgighter than red LEDs, which compensates for the filtering of light
Also, if your tail light doubles as a license plate light, it is not good to use a red LED.
Edited by TDM4ever, 21 October 2017 - 08:26 am.
#8 Riggers
Riggers
  • 531 posts
Posted 23 October 2017 - 10:54 am
I thought I'd just post up my experiences on these bulbs after trying two of them now in my stop/tail light. As I mentioned above the first one I tried was just a cheapo one from E.bay just to get an idea really. Now I've also tried a better one from a local independent car spares dealer. In both cases I'v found the light output to be way way down on a standard 5w/21w bulb, but probably more worrying is the difference BETWEEN the two phases There is very little difference between tail and stop/tail together. I would say that in daylight conditions your average Volvo driver would never notice that you're braking with some possibly nasty consequences. And as (I believe) they're illegal any subsequent insurance claim could be invalidated.
IMHO I would suggest leaving well alone until technology improves (which it will) and stick for now with a standard bulb.
Riggers.
