Posted 24 April 2014 - 11:54 am
Come to take the caliper off and guess what the bloody slide pin has gone and sheared.... )
I'm now at a loss as to what to do, I saw a NEW caliper from A J Sutton for £380, phew.
None that I could see on Ebay.
I wouldn't mind I only got it in Dec/Jan.
Desperate, any ideas????
Posted 24 April 2014 - 12:00 pm
Get a gneu sloide pin?
Got a piccy?
Posted 24 April 2014 - 12:51 pm
and I think that is a blind hole.so I can't just knock it out, can't say I fancy drilling it out
even if that's possible IMG_0277.JPG 104.54KB 3 downloads IMG_0278.JPG 127.31KB 2 downloads IMG_0279.JPG 151.99KB 1 downloads
Posted 24 April 2014 - 01:18 pm
The bolt is a couple of quid, If you dont fancy trying to get the old one out just take the caliper off and get local bike garage to do it, might want to spray some gt85 in it to loosen it up overnight tho...how annoying
Posted 24 April 2014 - 01:19 pm
Remove rear wheel take caliper of bike seperate from bracket and you should be able to get the offening bit out with a pair of mole grips.
Posted 24 April 2014 - 01:29 pm
if you still can't get it out after all the advice above, send the caliper to me.
I'll pop a slot drill down the 10mm hole to mill the broken end flat, then drill it out on the milling machine.
Then make you a new pair stainless slide pins (on the lathe)
The caliper couldn't have been doing much sliding seized like that.
Edited by leehenty, 24 April 2014 - 02:00 pm.
Posted 24 April 2014 - 02:44 pm
Have tried mole-grips, but stuck solid, just slides round.
So have ground flats on them and will leave soaking overnight.
IMG_0287.JPG 115.54KB 3 downloads IMG_0290.JPG 89.18KB 2 downloads
As you can see pad(S) seriously worn !!
Edited by spodge, 24 April 2014 - 02:44 pm.
Posted 24 April 2014 - 03:52 pm
Get it to Lee he can fix it .
Posted 24 April 2014 - 05:34 pm
Taken wheel & caliper off. 2nd slide bolt sheared
That's going to be a milling job IMHO, did you notice the rear brake was down on braking power ? I'd also check that the disc is still true. The good thing is the hydraulic part of the caliper is off now so that makes it much easier.
Thanks for the vote of confidence.
Edited by leehenty, 24 April 2014 - 05:48 pm.
Posted 24 April 2014 - 05:55 pm
gentle heat would help with removal.
Posted 24 April 2014 - 06:08 pm
Well braking power was OK, I think. I would have felt the pedal "oscillating"That's going to be a milling job IMHO, did you notice the rear brake was down on braking power ? I'd also check that the disc is still true. The good thing is the hydraulic part of the caliper is off now so that makes it much easier.
wouldn't I if the disk was out of true.
But the disk is heavily scored, I did have a bike a couple of years ago that passed an MOT with a similarly scored disk.
Posted 25 April 2014 - 03:28 pm
Slide pins : 5JW-25914-10 2off £3.07 each, plus v.a.t, in stock
Shim caliper : 5GJ-25827-00 2off £4.62 each, plus v.a.t, no stock, 3-5 days to order
Boot(2): 4TT-25937 00 2off £9.84 each, plus v.a.t, in stock
The boots were destroyed trying to get the pins out, there were NO shims fitted when I dismantled it??
Edited by spodge, 25 April 2014 - 03:30 pm.
Posted 25 April 2014 - 03:46 pm
ouch, over 10 quid for a rubber boot ?
