My 'new' bike - http://www.carpe-tdm...showtopic=31973
Tempest did a previous post ( http://www.carpe-tdm...showtopic=31955)before he decided to sell. I have been through it and made notes of the initial advice.
Spent a couple of hours today fitting the new battery (still firing on one) and now started taking bits off and have the carbs exposed. I now need to learn all about these, the component parts, possible quick fix and full strip down and rebuild deets. I'll spend more time later searching, but in the meantime anyone able to point to in the right direction for that lot (I 'know' it will be here somewhere....). I noticed on another post just now mention of diff carbs in the MK2's as well??
In addition to the above I don't want to keep putting the tank back on and off while working on this, so want to make a temp fuel supply. Any posts on that already anyone knows of?
Tank tap leaking when removing as well. Took it apart, cleaned it all up and is holding now, but washers hard and I broke the bottom off of the 'mouth' (if you know what I mean. Looks like 2 eyes and a mouth!), so Repair kit for that on the shopping list.
While taking off the tap.....loads of filth in bottom of tank!! I had the tank tilted forward on a makeshift bench, propped up on the airbox. Clever me thought I'd just dump a but of fuel out to get rid of that muck (or at least some of it). This is the colour of what came out!!
20150802_170104_small.jpg 255.82KB
3 downloads
Took it into the road and tipped more out. Job for winter......sort the inside of the tank. Added to shopping list. New fuel filter
Need a new one of these as well (tank to filter). I do have some reinforced fuel pipe in the garage, but tight angles and obviously don't want to kink it. What would you do? Make one up, or buy original?
20150802_160541_Small.jpg 91.94KB
1 downloads
Was quite surprised to see this on the top of my airbox as well!!
20150802_161351_small.jpg 188.87KB
1 downloads
Edited by idlebloke, 10 August 2015 - 07:41 pm.
