2 Line Brake Configuration
7 replies to this topic
#1 dablik
  • 10,760 posts
Posted 24 May 2020 - 06:58 pm
Can anyone confirm a 2 line brake set up furra mk2 would fit the 3vd ?? i assume they probably will or got to be very close, will need a small extension either way, i want to buy Venhill lines but they only offer 3 line oem set up and nope cant be arsed going through the rigmarole of ordering to build :) just want the press of a button and tell em to lengthen by 20mm...
I fank ewe..
#2 Studley Ramrod
  • 19,217 posts
Posted 24 May 2020 - 07:22 pm
The mk2 has a small bracket/pipe guide that bolts onto a bracket on the fork.  Dunno if you could get around this setup though.
#3 dapleb
  • 18,120 posts
Posted 24 May 2020 - 07:45 pm
I have MK2 system on my MK1 dabs. Just made a small bracket, works fine.
#4 dapleb
  • 18,120 posts
Posted 24 May 2020 - 08:02 pm
Loike dis
[attachment=13214:Screenshot_20200524-205238~2.png]
#5 Studley Ramrod
  • 19,217 posts
Posted 24 May 2020 - 08:13 pm
Canny lad. :good:
#6 dablik
  • 10,760 posts
Posted 24 May 2020 - 08:49 pm
Cheers chappies, very ingenious daps but snot wot i meant, i want 2 lines from MC with double banjo orf to each caliper, so, Venhill 2 line set up only availabe for mk2 not for 3vd.............they only offer 3 line kit loike oem 3vd set, so if i want 2 line will need to purchase mk2 kit for mk1 boike.....anyhoo thems gonna fit aint they judging by previous answers........
#7 poppykle
poppykle
  • 83 posts
Posted 24 May 2020 - 11:41 pm
Why the double line dablik?  My understanding is that a double line configuration is less efficient than the standard set up. Your MC may not provide enough pressure and you could lose braking performance.
#8 dablik
  • 10,760 posts
Posted 25 May 2020 - 09:14 am
It's hydraulics so wont be much difference between set up wether it's 2 or 3 line, the only thing that would make a difference is bore size of lines, MC gives plenty of pressure as it's 14mm (same as 2002 9r) and having already had a brand new 2 line set up and bled on the bike i like the feel of the brake lever so staying put with that decision..the new previous lines are damaged so wont use..
