Remap Advice
1 reply to this topic
#1 Jim55
Jim55
  • 41 posts
Posted 09 October 2021 - 07:00 pm
Does anyone know who can remap my 07 niner,IV fitted black widow cans ,it sounds amazing but I'm sure it's a bit lean and lost a few horses ( Scotland preferably but I would travel to a tdm specialist) thanks😎
#2 fixitsan
  • 4,676 posts
Posted 10 October 2021 - 11:26 am
Hi Jim , I had mine done by Samios Motorsport in Greece, which meant sending it away.
It seems now that only a small number of versions of ECU. mostly the early ones without an Immobiliser or ABS can be programmed.
Where in Scotland are you ? I'm about 15 miles west of Edinburgh, you're welcome to try the ECU on your bike, but if it has either of the above features then i dont think it will work.
To find out if yours can be programmed you will need to send a photo of the label on the ECU to Samios, who then look through their ECU reference books to see if it's possible.
Prior to the remap I had done the airbox mod, and fitted a resistor in series with the airbox temperature sensor, and advanced the ignition timing by 3 or 4 degrees (by using a dremel to slot the crank position sensor mounting bracket screw holes)
I also run a -1 tooth front sprocket which I think on it's own makes the gears more useful, at the slight of expense of using a tad more fuel
