Pilot Screws Lean / Rich
14 replies to this topic
#1 wicklamulla
Posted 18 May 2019 - 01:55 pm
so the pilot screws are meant to be 2 turns out according to Haynes.   If you wind them out more you are leaning off the mixture i guess?
LHS carb is set at 2.25  turns out and RHS is set at 3.5 turns out,  i notice when i let it idle the RHS down poipe gets very hot compared to the LHS one so am i right in saying the right one is running lean?
The pilots as yew all know are a pig to get to but once set up properly they shudn't need adjusting again i hope! I was gonna look at buying and fitting those long remote pilot screw adjusters which would make adjustment a doddle and as the extensions are similar to the remote idle control knob and they cud be placed behind the side panels to facilitate easy access and adjustment.
The bike still has the original problem whereby it'll only idle on full choke and if i try and apply throttle it dies and if i take off the choke it dies,  i failed to remove the carb. float bowls as the screws were stuck fast so i will apply more carb. cleaner to the inlets and see if that helps clean tings up and improves running.  I have some Seafoam fuel system cleaner on it's way here so will also try that.   The bike is unrideable at present.
#2 Pedro
Pedro
  • 266 posts
Posted 18 May 2019 - 03:20 pm
Sounds like deffo a blockage in the carbs. As i understand it the pilots screws only deal with the tick over mixture, maybe overlaps a bit into the secondary jets. I'd say the probems is with the jets being blocked inside, hence when you open the throttle, no fuel, no bang bang.  I'd  be interested to find out what the seafoam does. Yankee friends swear by it but i've never heard much about them over here.  I'd say a carb strip is eminent even if you have to use swear words and divine interverntion on the bowl screws.
Pedro
#3 dablik
  • 10,742 posts
Posted 18 May 2019 - 04:21 pm
Wickers sometimes i've found even a JIS wont budge some screws, if you have them on the bench think i would monky jizz em and put a small pair of molies on then replace with new or Alan.. remember to hold the bowl flat when undoing seems to help.
#4 wicklamulla
Posted 18 May 2019 - 11:19 pm
Pedro / Dablik,
Ok we have moved forward as the  bike will now rev out using the throttle but still requires choke to idle. I will keep it running by feathering the throttle and i'll keep feeding it carb cleaner direct into the carbs and see if it cleans out the clogged up jets. Oil administer the Seafoam on monday and run it thru and see what happens.
Edited by wicklamulla, 18 May 2019 - 11:20 pm.
#5 dablik
  • 10,742 posts
Posted 19 May 2019 - 08:32 am
When Dave used Seafoam he left it in to work furra a good cupla days, was like following smokey the bandit afterwards but cleaned up his hesistant carbs no end.
#6 Pedro
Pedro
  • 266 posts
Posted 19 May 2019 - 12:09 pm
:good:
#7 Studley Ramrod
  • 19,211 posts
Posted 19 May 2019 - 01:36 pm
Pedro / Dablik,
Don't forget to read the instructions first Ken. :D
#8 wicklamulla
Posted 20 May 2019 - 01:22 am
You Betcha!
#9 dandywarhol
Posted 24 May 2019 - 07:54 pm
If the screw is above the fuel level it's out to enrichen and vice versa
#10 TDM4ever
TDM4ever
  • 302 posts
Posted 25 May 2019 - 07:22 am
..monky jizz ...
:huh:  :huh:  :rotflmmfao:
#11 MipeTDM
MipeTDM
  • 92 posts
Posted 25 May 2019 - 06:02 pm
No, its the other way around as far as I recall
Not necessarily, it can also be the case they are not synchronized, so one cylinder is doing most of the works at idle.
I used this and a small mirror to do the adjustments.
Not very easy, but possible.
I'd try adjusting them, and also check synchronisation: the screw in the middle of the two carbs. Try moving the slides up on the carbs and check the opening of the butterfly valves visually. Big adjustment errors can be spotted easily
#12 wicklamulla
Posted 26 May 2019 - 01:02 am
Thanks Mipe,  i used a bore scope and a similar tool to adjust the pilots.  it now runs and idles erratically but it is just rideable but i am not happy with it.  i will wind the pilots out some more as i set them to 2 turns out as that what the manual states.  I checked the carb balance and they are very close together,  i think the TPS is out of adjustment too so i'll reset that to spec. Love this bike and i need to sort this out,  my neglect has brought this on to be fair and truthful!
#13 MipeTDM
MipeTDM
  • 92 posts
Posted 26 May 2019 - 12:50 pm
In the end the issue will surely be simple. Finding it is generally the difficult part...
Have you checked, if the carb slides both move simultaneously on the throttle, with the bike running without air filter so you can see it?
#14 danjohnston89
danjohnston89
  • 63 posts
Posted 09 September 2019 - 03:11 pm
Wicklamulla did you ever get this sorted? I am experiencing very similar issues
#15 wicklamulla
Posted 09 September 2019 - 05:13 pm
Wicklamulla did you ever get this sorted? I am experiencing very similar issuesWicklamulla did you ever get this sorted? I am experiencing very similar issues
Dan I pushed it to the back of the garage and pulled out another bike instead. I'll be taking the carbs out again soon though as I want to try cleaning them some more.
